Author: wmb Date: Fri Feb 4 02:42:30 2011 New Revision: 2169 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2169
Log: XO-1.75 touchscreen demo - zooms and pans the screen image with gestures.
Added: cpu/arm/olpc/1.75/pinch.fth Modified: cpu/arm/olpc/1.75/fw.bth
Modified: cpu/arm/olpc/1.75/fw.bth ============================================================================== --- cpu/arm/olpc/1.75/fw.bth Thu Feb 3 21:05:52 2011 (r2168) +++ cpu/arm/olpc/1.75/fw.bth Fri Feb 4 02:42:30 2011 (r2169) @@ -164,6 +164,9 @@ fload ${BP}/cpu/x86/pc/olpc/via/copynand.fth fload ${BP}/cpu/arm/olpc/1.75/exc7200-touchscreen.fth \ Touchscreen driver and diagnostic
+fload ${BP}/cpu/arm/olpc/1.75/pinch.fth \ Touchscreen gestures +: pinch " pinch" screen-ih $call-method ; + fload ${BP}/cpu/arm/mmp2/keypad.fth [ifndef] cl2-a1 stand-init: keypad
Added: cpu/arm/olpc/1.75/pinch.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/1.75/pinch.fth Fri Feb 4 02:42:30 2011 (r2169) @@ -0,0 +1,188 @@ +\ See license at end of file +purpose: Zoom and pan the text scroller with touchscreen gestures + +dev screen +: dst-size@ ( -- w h ) h# 108 lcd@ lwsplit ; +: dst-size! ( w h -- ) wljoin h# 108 lcd! ; +: dst-offset@ ( -- x y ) h# 100 lcd@ lwsplit ; +: dst-offset! ( x y -- ) wljoin h# 100 lcd! ; +: scr-size@ ( -- w h ) h# 104 lcd@ lwsplit ; +: half-size ( -- w h ) dst-size@ swap 2/ swap 2/ ; +: image-center-xy ( -- x y ) half-size dst-offset@ xy+ ; + +: xy-max ( x1 y1 x2 y2 -- xmax ymax ) rot max >r max r> ; +: xy-min ( x1 y1 x2 y2 -- xmin ymin ) rot min >r min r> ; +d# 60 d# 80 2constant min-wh +: set-dst-size ( w h -- ) + scr-size@ xy-min min-wh xy-max dst-size! +; +\ This is an attempt to delay the operation until "retrace", but +\ it doesn't work very well; it's currently worse than nothing. +: wait-frame ( -- ) + 0 h# 1c4 lcd! begin h# 1c4 lcd@ until +; +: set-dst-offset ( x y -- ) + \ Keep the full image on-screen + 0 0 xy-max ( x' y' ) + + 2dup dst-size@ xy+ ( x y extent-x extent-y ) + scr-size@ 2swap xy- ( x y margin-x margin-y ) + \ A negative margin means part of the image is off the screen + \ Positive margin is okay; we only adjust if margin is negative. + 0 0 xy-min ( x y adjust-x adjust-y ) + xy+ ( x' y' ) + + dst-offset! ( ) +; +: resize-image ( xnum ynum xdenom ydenom old-w old-h -- ) + 2>r ( xnum xdenom ynum ydenom r: w h ) + rot swap ( xnum xdenom ynum ydenom r: w h ) + 2r> ( xnum xdenom ynum ydenom w h ) + swap >r ( xnum xdenom ynum ydenom h r: w ) + -rot */ ( xnum xdenom h' r: w ) + r> swap >r ( xnum xdenom w r: h' ) + -rot */ ( w' r: h' ) + r> ( w' h' ) + set-dst-size ( ) +; +: rx ( 6*n -- 6*n ) 0 5 do i pick .d -1 +loop cr resize-image ; +: arx ." A " rx resize-image ; +: brx ." B " rx resize-image ; + +0 0 2value p0 +0 0 2value p1 +0 0 2value base-distance +0 0 2value base-wh +0 0 2value base-touch-xy +0 0 2value base-center-xy + +\ Try to keep the center of the image in the same place after resizing +: recenter-image ( -- ) + base-center-xy half-size xy- + set-dst-offset +; + +0 value down0? +0 value down1? + +: distance ( -- x y ) p1 p0 xy- ; + +: xy-abs ( x y -- abs-x abs-y ) swap abs swap abs ; + +0 value touch-ih +: open-touch ( -- ) + touch-ih 0= if + " /touchscreen" open-dev to touch-ih + then + touch-ih 0= abort" Can't open touchscreen" +; +: close-touch ( -- ) touch-ih ?dup if close-dev 0 to touch-ih then ; + +: mark-touch ( -- ) + p0 to base-touch-xy + image-center-xy to base-center-xy +; +: mark-size ( -- ) + dst-size@ to base-wh + distance xy-abs to base-distance +; +: move-image ( newx,y -- ) +\ wait-frame + base-touch-xy xy- base-center-xy half-size xy- xy+ set-dst-offset +; +: resize&recenter ( -- ) +\ wait-frame + distance xy-abs base-distance base-wh resize-image \ brx + recenter-image +; +: do-touch0 ( x y down? -- ) + -rot to p0 if ( ) \ Down + down1? if \ Double-touch - resize + down0? if \ Not the initial touch pair - resize the screen image + resize&recenter + else \ Initial touch pair - establish the baseline size + mark-size + then + else \ The second finger is up, so this is a move + down0? if \ Not the initial touch - move the image + p0 move-image + else \ Initial touch - establish the base position + mark-touch + then + then + + true to down0? + else \ Up + false to down0? + then +; +: do-touch1 ( x y down? -- ) + -rot to p1 if ( ) \ Down + down0? if \ Double-touch - resize + down1? if \ Not the initial touch pair - resize the window + resize&recenter + else \ Initial touch pair - establish the baseline size + mark-size + + \ Initial touch of second finger - reestablish the base position + \ in case the image was moved after the first finger when down + mark-touch + then + else \ The first finger is now up - do nothing in this case + then + + true to down1? + else \ Up + \ When the second finger goes up, we again must reestablish the base position + \ so subsequent movement of the first finger will cause stable image movement + mark-touch + false to down1? + then +; +: touch>screen ( x y -- x' y' ) + scr-size@ 1 1 xy- xy* + swap d# 15 rshift swap d# 15 rshift +; +: do-gesture ( -- ) + " get-touch?" touch-ih $call-method 0= if exit then ( x y z down? touch# ) + 2>r ( x y z r: down? touch# ) + drop ( x y r: down? touch# ) + \ Convert from touchscreen to pixel coordinates + touch>screen ( x y r: down? touch# ) + 2r> ( x y down? touch# ) + case + 0 of do-touch0 endof + 1 of do-touch1 endof + ( default ) >r 3drop r> + endcase +; +: pinch + open-touch + begin do-gesture key? until + close-touch +; +dend + +\ LICENSE_BEGIN +\ Copyright (c) 2011 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
