Author: wmb Date: 2009-08-05 22:36:19 +0200 (Wed, 05 Aug 2009) New Revision: 1275
Modified: cpu/x86/pc/olpc/via/dsdt.dsl Log: Via DSDT - wakeup changes from Paul Fox.
Modified: cpu/x86/pc/olpc/via/dsdt.dsl =================================================================== --- cpu/x86/pc/olpc/via/dsdt.dsl 2009-08-05 03:25:58 UTC (rev 1274) +++ cpu/x86/pc/olpc/via/dsdt.dsl 2009-08-05 20:36:19 UTC (rev 1275) @@ -121,42 +121,44 @@
OperationRegion(\GPST, SystemIO, 0x0420, 0x2) Field(\GPST, ByteAcc, NoLock, Preserve) { - GS00,1, - GS01,1, - GS02,1, - GS03,1, - GS04,1, - GS05,1, - GS06,1, - GS07,1, - GS08,1, - GS09,1, - GS10,1, - GS11,1, // lid - GS12,1, - GS13,1, - GS14,1, - GS15,1, + GS00,1, // GPI0 + GS01,1, // GPI1 (GPWAKE) + GS02,1, // internal KBC PME + GS03,1, // V1 Interrupt + GS04,1, // EXTSMI# + GS05,1, // PME# + GS06,1, // INTRUDER# + GS07,1, // GP3 timer timeout + GS08,1, // ring + GS09,1, // mouse controller PME + GS10,1, // thermal detect (ebook) + GS11,1, // LID# + GS12,1, // battery low + GS13,1, // HDAC wakeup + GS14,1, // USB wakeup + GS15,1, // north module SERR# }
-// PMIO_RX24/5 -OperationRegion(\GPSE, SystemIO, 0x0424, 0x2) // Genernal Purpose SMI Enable +// PMIO_RX22/3 +OperationRegion(\GPSE, SystemIO, 0x0422, 0x2) // Genernal Purpose SCI Enable Field(\GPSE, ByteAcc, NoLock, Preserve) { - GPS0, 1, // GPI0 SMI Enable - GPS1, 1, // GPI1 SMI Enable + GPS0, 1, // GPI0 SCI Enable + GPWK, 1, // GPI1 SCI Enable KBCE, 1, // PS2 KB PME Enable - , 1, - EXTE, 1, // EXT SMI Enable + , 1, + EXTE, 1, // EXTSMI# Enable PME, 1, // PCI PME Enable , 2, RING, 1, // Ring Wakeup - , 2, + , 1, + THRM, 1, // Ebook/Thermal detect LID, 1, // Lid Wakeup - , 2, + , 1, // BATLOW Enable + HDA, 1, // HDA Enable USBE, 1, // USB Resume - , 1, + , 1, // NB SERR Detect } - + // PMIO_RX28/9 OperationRegion(\Glos, SystemIO, 0x0428, 0x2) // Global Status Field(\Glos, ByteAcc, NoLock, Preserve) { @@ -183,10 +185,19 @@ , 1, // , 1, // , 1, // battery low enable (0 == enable) - , 1, // therm polarity (1 == falling) + TPOL, 1, // therm polarity (1 == falling) LPOL, 1, // lid polarity (1 == falling) }
+// from BIOS porting guide, section 13.2.2.4 +OperationRegion(\ENB, SystemIO, 0x048c, 0x1) // SMI enable, lid edge polarity +Field(\ENB, ByteAcc, NoLock, Preserve) { + , 3, + TENB, 1, // therm enable (1 == enabled) + , 4, + +} + OperationRegion(\Stus, SystemIO, 0x0430, 0x1) // Global Status Field(\Stus, ByteAcc, NoLock, Preserve) { PADS, 8, @@ -204,23 +215,44 @@ // Scope(_GPE) { + Method(_L01) { + UPUT (0x31) // 1 + Notify(_SB.PCI0.EC, 0x80) // GPWAKE, from the EC + } + Method(_L02) { + UPUT (0x33) // 3 Notify(_SB.PCI0.VT86.PS2K, 0x02) //Internal Keyboard PME Status }
Method(_L04) { + UPUT (0x34) // 4 Notify(_SB.SLPB, 0x80) }
Method(_L05) { + UPUT (0x35) // 5 Notify(_SB.PCI0,0x2) }
+ Method(_L08) { // A-series EBOOK event (RING) (will go away) + UPUT (0x64) // d + Notify(_SB.PCI0.EBKA, 0x80) + } + Method(_L09) { + UPUT (0x39) // 9 Notify(_SB.PCI0.VT86.PS2M, 0x02) //Internal Mouse Controller PME Status }
+ Method(_L0A) { // EBOOK event (THRM#) + UPUT (0x65) // e + Not(TPOL, TPOL) // Flip the therm polarity bit + Notify(_SB.PCI0.EBK, 0x80) + } + Method(_L0B) { // LID event + UPUT (0x66) // f Not(LPOL, LPOL) // Flip the lid polarity bit Notify(_SB.PCI0.LID, 0x80) } @@ -320,27 +352,27 @@ Return (0x00) }
-Method(STRC, 2) { // Compare two String - If(LNotEqual(Sizeof(Arg0), Sizeof(Arg1))) { - Return(1) - } - - Add(Sizeof(Arg0), 1, Local0) - - Name(BUF0, Buffer(Local0) {}) - Name(BUF1, Buffer(Local0) {}) - - Store(Arg0, BUF0) - Store(Arg1, BUF1) - - While(Local0) { - Decrement(Local0) - If(LNotEqual(Derefof(Index(BUF0, Local0)), Derefof(Index(BUF1, Local0)))) { - Return(1) - } - } - Return(0) // Str1 & Str2 are match -} +// Method(STRC, 2) { // Compare two String +// If(LNotEqual(Sizeof(Arg0), Sizeof(Arg1))) { +// Return(1) +// } +// +// Add(Sizeof(Arg0), 1, Local0) +// +// Name(BUF0, Buffer(Local0) {}) +// Name(BUF1, Buffer(Local0) {}) +// +// Store(Arg0, BUF0) +// Store(Arg1, BUF1) +// +// While(Local0) { +// Decrement(Local0) +// If(LNotEqual(Derefof(Index(BUF0, Local0)), Derefof(Index(BUF1, Local0)))) { +// Return(1) +// } +// } +// Return(0) // Str1 & Str2 are match +// }
// // System Bus @@ -352,10 +384,8 @@ Device (SLPB) { Name (_HID, EISAID("PNP0C0E")) // Hardware Device ID SLEEPBTN - Method(_STA, 0) { - Return(0x0B) // non-present, enabled, functioning - } - + Name (_STA, 0) // not present on XO. note that there are still + // Notify() calls to SLPB -- not sure what that will do. Name(_PRW, Package(2){0x04,5}) //Internal Keyboard Controller PME Status; S5 }
@@ -370,6 +400,7 @@
Method(_INI, 0) { + UPUT (0x4a) // J }
Name (_S3D, 3) @@ -1160,7 +1191,7 @@ Device(PS2M) //PS2 Mouse { Name(_HID,EISAID("PNP0F13")) - Name(_STA, 0x0F) + Name(_STA, 0x0) // not present: not used on XO Name(_CRS, ResourceTemplate () { IRQNoFlags () {12} }) Name(_PRW, Package() {0x09, 0x04}) } @@ -1170,7 +1201,7 @@ Name(_HID,EISAID("PNP0303")) Name(_CID,EISAID("PNP030B")) // Microsoft reserved PNP ID
- Name(_STA,0x0F) + Name(_STA,0x0) // not present: not used on XO
Name (_CRS, ResourceTemplate () { @@ -1864,7 +1895,6 @@ { If (LNot (Acquire (ACMX, 5000))) { - UPUT (0x69) // i // Store (ECRD (0xFB5F), Local0) Store (ECR1 (0x2c), Local0) // CMD_READ_BATTERY_TYPE // Store (ECRD (0xF929), Local1) // FIXME -- BAT_SOC_WARNNING @@ -2255,6 +2285,57 @@ } } // Device(P2PB)
+ Device (EBK) { + Name (_PRW, Package (0x02) { 0x0A, 0x04 }) // Event 0A, wakes from S4 + + Method(_INI, 0) + { + UPUT (0x6b) // k + Store (One, TENB) // Enable ebook (THERM#) + Store (One, THRM) + } + + Method(EBK) { + If (TPOL) { // ebook is "open" + UPUT (0x65) // e + } Else { + UPUT (0x45) // E + } + Return(TPOL) + } + } // Device(EBK) + + // RING-based ebook support, on A-series boards + Device (EBKA) { + Name (_PRW, Package (0x02) { 0x08, 0x04 }) // Event 08, wakes from S4 + + Method(_INI, 0) + { + UPUT (0x69) // i + Store (One, RING) + } + + Method(EBK) { + If (TPOL) { // ebook is "open" + UPUT (0x65) // e + } Else { + UPUT (0x45) // E + } + Return(TPOL) + } + } // Device(EBKA) + + Device (EC) { + Name (_PRW, Package (0x02) { 0x01, 0x04 }) // Event 01, wakes from S4 + + Method(_INI, 0) + { + UPUT (0x49) // I + Store (One, GPWK) // Enable gpwake + } + + } // Device(EC) + Device (LID) { Name (_HID, EisaId ("PNP0C0D")) Name (_PRW, Package (0x02) { 0x0B, 0x04 }) // Event 0B, wakes from S4 @@ -2265,8 +2346,7 @@ } Else { UPUT (0x4c) // L } - Store (Zero, GS11) // Clear lid - Return(LPOL) + Return(LNot(LPOL)) // pgf is unclear on why this polarity is correct }
} // Device(LID)
