Author: wmb Date: Wed Dec 5 04:44:52 2012 New Revision: 3470 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3470
Log: Start of a driver for FTDI serial chips. Needs fleshing out.
Added: dev/usb2/device/serial/ftdi.fth
Added: dev/usb2/device/serial/ftdi.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ dev/usb2/device/serial/ftdi.fth Wed Dec 5 04:44:52 2012 (r3470) @@ -0,0 +1,72 @@ +purpose: Driver for FTDI USB serial chips + +8 buffer: ftdi-buf + +0 value ftdi-port \ 0 for single-interface devices and SIOA, 1 for SIOB, 2 for parallel port + +\ Helper function +: ftdi-set ( value request -- ) + >r >r 0 0 ftdi-port r> h# 40 r> control-set drop +; + +\ Read internal registers +: ftdi@ ( index -- w ) + >r ftdi-buf 2 r> 0 h# c0 h# 90 control-get 2drop + ftdi-buf c@ ftdi-buf 1+ c@ bwjoin +; + +\ Various resets +: ftdi-reset ( -- ) 0 0 ftdi-set ; +: ftdi-flush-rx ( -- ) 0 1 ftdi-set ; +: ftdi-flush-tx ( -- ) 0 2 ftdi-set ; + +: ftdi-baud ( baud -- ) + \ There are some high bits for fractional divisors that we don't use + d# 48000000 swap rounded-/ ( divisor ) + 0 swap 3 ftdi-set +; + +: ftdi-modem-ctl ( code -- ) 1 ftdi-set ; +: ftdi-rts-on ( -- ) h# 202 ftdi-modem-ctl ; +: ftdi-rts-off ( -- ) h# 200 ftdi-modem-ctl ; +: ftdi-dtr-on ( -- ) h# 101 ftdi-modem-ctl ; +: ftdi-dtr-off ( -- ) h# 100 ftdi-modem-ctl ; + +: ftdi-flow-ctl ( code -- ) 2 ftdi-set ; +: ftdi-flow-none ( -- ) 0 ftdi-flow-ctl ; +: ftdi-flow-rts-cts ( -- ) h# 100 ftdi-flow-ctl ; +: ftdi-flow-dtr-dsr ( -- ) h# 200 ftdi-flow-ctl ; +: ftdi-flow-xon-xoff ( -- ) h# 400 ftdi-flow-ctl ; + +\ h# 800 for 1.5 stop bits, h# 1000 for 2 stop bits +\ h# 300 for mark parity, h# 400 for space parity +: ftdi-data ( code -- ) 4 ftdi-set ; +: ftdi-8n1 ( -- ) 8 ftdi-data ; +\ : ftdi-8o1 ( -- ) h# 18 ftdi-data ; +\ : ftdi-8e1 ( -- ) h# 28 ftdi-data ; +\ : ftdi-7e1 ( -- ) h# 27 ftdi-data ; +\ : ftdi-7o1 ( -- ) h# 17 ftdi-data ; + +: ftdi-break-on ( -- ) h# 4000 ftdi-data ; +\ To send a break, I suppose that you do ftdi-break-on, delay awhile, +\ then ftdi-8n1 or whatever your data format is. + +\ Commands that we're unlikely to need +\ : ftdi-set-event-char ( char -- ) 6 ftdi-set ; +\ : ftdi-set-error-char ( char -- ) 7 ftdi-set ; +\ : ftdi-set-latency ( ms -- ) 9 ftdi-set ; + +\ CTS: 10 DSR: 20 RI: 40 CD: 80 +\ DR: 100 OR: 200 PE: 400 FE: 800 Break: 1000 THRE: 2000 TE: 4000 RXERR: 8000 +: ftdi-modem@ ( -- status ) + ftdi-buf 2 ftdi-port 0 h# c0 5 control-get 2drop + ftdi-buf c@ ftdi-buf 1+ c@ bwjoin +; + +\ Data is received on bulk endpoint 1 +\ Byte 0 is modem status (CTS - CD as above) +\ Byte 1 is line status (DR - RXERR as above) +\ If there is any real data, it will be returned in bytes 2, ... +\ If there is no data, 2-byte status messages are sent every 40 ms. + +\ Data is transmitted on bulk endpoint 2, verbatim.
