Author: wmb Date: Thu Jul 12 22:49:36 2012 New Revision: 3059 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3059
Log: OLPC ARM - moved cpu/arm/olpc/testitems.fth down into 1.75 in preparation for copying into different platform directories and removing ifdefs.
Added: cpu/arm/olpc/1.75/testitems.fth - copied unchanged from r3050, cpu/arm/olpc/testitems.fth Deleted: cpu/arm/olpc/testitems.fth Modified: cpu/arm/olpc/build-fw.fth
Copied: cpu/arm/olpc/1.75/testitems.fth (from r3050, cpu/arm/olpc/testitems.fth) ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/1.75/testitems.fth Thu Jul 12 22:49:36 2012 (r3059, copy of r3050, cpu/arm/olpc/testitems.fth) @@ -0,0 +1,111 @@ +purpose: Platform-specific layout of diagnostic GUI menu items + +d# 5 to #mfgcols +d# 4 to #mfgrows + +icon: cpu.icon rom:cpu.565 +icon: spi.icon rom:spi.565 +icon: ram.icon rom:ram.565 +icon: sdcard.icon rom:sdcard.565 +icon: usb.icon rom:usb.565 +icon: battery.icon rom:battery.565 +icon: camera.icon rom:camera.565 +icon: wifi.icon rom:wifi.565 +icon: audio.icon rom:audio.565 +- olpc-cl3 icon: touchpad.icon rom:touchpad.565 ++ olpc-cl3 icon: touchscreen.icon rom:touchpad.565 +icon: display.icon rom:display.565 +- olpc-cl3 icon: keyboard.icon rom:keyboard.565 +icon: timer.icon rom:timer.565 +icon: clock.icon rom:clock.565 +icon: ebook.icon rom:ebook.565 +icon: leds.icon rom:leds.565 + ++ olpc-cl3 : screen-kbd-scroller ( -- ) blank-screen open-screen-keyboard ; ++ olpc-cl3 ' screen-kbd-scroller to scroller-on ++ olpc-cl3 ' close-screen-keyboard to scroller-off + +: cpu-item ( -- ) " /cpu" mfg-test-dev ; +: battery-item ( -- ) " /battery" mfg-test-dev ; +: spiflash-item ( -- ) " /flash" mfg-test-dev ; +: memory-item ( -- ) " /memory" mfg-test-dev ; ++ olpc-cl2 : usb-item ( -- ) " /usb/hub" mfg-test-dev ; ++ olpc-cl3 : otg-item ( -- ) " otg" mfg-test-dev ; ++ olpc-cl3 : usb-item ( -- ) " usba" mfg-test-dev ; +: int-sd-item ( -- ) " int:0" mfg-test-dev ; +- olpc-cl3 : ext-sd-item ( -- ) " ext:0" mfg-test-dev ; +: rtc-item ( -- ) " /rtc" mfg-test-dev ; +: display-item ( -- ) " /display" gfx-test-dev ; +: audio-item ( -- ) " /audio" mfg-test-dev ; +: camera-item ( -- ) " /camera" gfx-test-dev ; +: wlan-item ( -- ) " /wlan" mfg-test-dev ; +: timer-item ( -- ) " /timer" mfg-test-dev ; +- olpc-cl3 : touchpad-item ( -- ) " mouse" mfg-test-dev ; ++ olpc-cl3 : touchscreen-item ( -- ) " /touchscreen" gfx-test-dev ; +- olpc-cl3 : keyboard-item ( -- ) " keyboard" mfg-test-dev ; +: switch-item ( -- ) " /accelerometer" mfg-test-dev " /switches" mfg-test-dev ; +: leds-item ( -- ) " /leds" mfg-test-dev ; + +: olpc-test-menu-items ( -- ) + 0 to #mfgtests + 1 0 set-row-col + +\ " CPU" +\ ['] cpu-item cpu.icon add-icon + + " SPI Flash: Contains EC code, firmware, manufacturing data." + ['] spiflash-item spi.icon add-icon + + " RAM chips" + ['] memory-item ram.icon add-icon + + " Internal mass storage" + ['] int-sd-item sdcard.icon add-icon + +- olpc-cl3 " Plug-in SD card" +- olpc-cl3 ['] ext-sd-item sdcard.icon add-icon + + " Wireless LAN" + ['] wlan-item wifi.icon add-icon + + " Display" + ['] display-item display.icon add-icon + + " Camera" + ['] camera-item camera.icon add-icon + + " Audio: Speaker and microphone" + ['] audio-item audio.icon add-icon + + " Battery" + ['] battery-item battery.icon add-icon + + " RTC (Real-Time Clock)" + ['] rtc-item clock.icon add-icon + ++ olpc-cl2 " USB ports" ++ olpc-cl3 " USB-A port" + ['] usb-item usb.icon add-icon + ++ olpc-cl3 " USB OTG port" ++ olpc-cl3 ['] otg-item usb.icon add-icon + + \ These are last because they require user participation. + \ The earlier tests are all included in automatic batch-mode. + +- olpc-cl3 " Keyboard" +- olpc-cl3 ['] keyboard-item keyboard.icon add-icon + +- olpc-cl3 " Touchpad" +- olpc-cl3 ['] touchpad-item touchpad.icon add-icon + ++ olpc-cl3 " Touchscreen" ++ olpc-cl3 ['] touchscreen-item touchscreen.icon add-icon + + " LEDs" + ['] leds-item leds.icon add-icon + + " Switches and Accelerometer" + ['] switch-item ebook.icon add-icon +; +' olpc-test-menu-items to test-menu-items
Modified: cpu/arm/olpc/build-fw.fth ============================================================================== --- cpu/arm/olpc/build-fw.fth Thu Jul 12 22:36:46 2012 (r3058) +++ cpu/arm/olpc/build-fw.fth Thu Jul 12 22:49:36 2012 (r3059) @@ -794,7 +794,7 @@ : ?text-on ( -- ) key? if text-on visible then ; [then]
-fload ${BP}/cpu/arm/olpc/testitems.fth +fload ${BP}/cpu/arm/olpc/1.75/testitems.fth
: startup ( -- ) standalone? 0= if exit then
