Author: quozl Date: Wed Sep 5 13:13:15 2012 New Revision: 3288 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3288
Log: OLPC XO-4 - Neonode, graphical Forced LED Levels tool, shows an indicator for each signal, shaded by level, bright for good, black for bad, tiny white dot for inadequate
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Wed Sep 5 05:29:58 2012 (r3287) +++ cpu/arm/olpc/nn-touchscreen.fth Wed Sep 5 13:13:15 2012 (r3288) @@ -16,8 +16,9 @@ : bytes-out ( byte .. #bytes -- ) " bytes-out" $call-parent ;
create nn-os \ open short test -create nn-fll \ forced led levels test +create nn-fll \ forced LED levels test create nn-version \ version display +create nn-watch-fll \ forced LED levels test, graphical variant
\ create nn-fss \ optional fixed signal strength test \ create nn-ls \ optional low signals test @@ -43,6 +44,8 @@ : 2u.x base @ >r hex 0 <# # # #> type r> base ! ; [then]
+: x>x' ( x -- x' ) screen-w swap - ; \ reverse x coordinate + : set-gpios [ifdef] olpc-cl2 0 1e2bc io!@ \ TWSI4_SCL @@ -151,7 +154,7 @@ in? if \ FIXME: only handles one subpacket pbuf 2+ c@ h# 04 = if - screen-w pbuf 4 + w@ - ( x ) + pbuf 4 + w@ x>x' ( x ) pbuf 6 + w@ ( x y ) pbuf 8 + c@ 3 and 0= ( x y down? ) true ( x y buttons true ) @@ -496,9 +499,13 @@ [then] ;
-: test-fll-axis ( axis -- ) +: (fll) ( axis# -- ) h# 20 h# 02 h# ee 4 bytes-out h# 1c d# 200 anticipate +; + +: test-fll-axis ( axis -- ) + (fll) pbuf 4 + c@ 2/ 0 do i pbuf 5 + over 3 * + >r ( i r:frag ) 2* dup r@ 1+ c@ r@ c@ 4 rshift h# f and test-fll-signal @@ -516,6 +523,86 @@
+[ifdef] nn-watch-fll \ forced LED levels test, graphical variant + + +d# 30 value r \ size of blocks +d# 1200 2/ r 2/ - value yx \ the y axis' stable x coordinate +d# 900 2/ r 2/ - value xy \ the x axis' stable y coordinate + +: bigdot ( x y -- ) + pixcolor @ -rot r r ( color x y w h ) + fill-rectangle-noff ( ) +; + +: signal>colour ( signal-value -- colour ) + d# 3 rshift dup d# 5 lshift over d# 11 lshift or or +; + +: ys>xy ( signal# -- x y ) + yx swap ( x signal# ) + screen-h yleds 2* / * ( x y ) + r 2/ + ( x y ) +; + +: xs>xy ( signal# -- x y ) + 2+ screen-w xleds 2* / * r - ( x ) + x>x' ( x' ) + r 2/ + + xy ( x y ) +; + +: big>little ( x y -- x' y' ) + r 2/ + 3 - swap + r 2/ + 2 - swap +; + +0 value axis# +: watch-fll-signal ( signal# signal-value led-level -- ) + >r ( signal# signal-value r: led-level ) + signal>colour pixcolor ! ( signal# r: led-level ) + axis# if ( signal# r: led-level ) \ y + ys>xy + else ( signal# r: led-level ) \ x + xs>xy + then ( x y r: led-level ) + 2dup bigdot ( x y r: led-level ) + r> ( x y led-level ) + h# c > if ( x y ) + white pixcolor ! ( x y ) + big>little ( x' y' ) + dot ( ) + else + 2drop + then ( ) +; + +: watch-fll-axis ( axis# -- ) + dup to axis# ( axis# ) + (fll) + pbuf 4 + c@ 2/ 0 do + i pbuf 5 + over 3 * + >r ( i r:frag ) + 2* dup r@ 1+ c@ r@ c@ 4 rshift h# f and watch-fll-signal + 1+ r@ 2+ c@ r@ c@ h# f and watch-fll-signal + r> drop ( ) + loop +; + +: watch-fll + black 0 0 screen-w screen-h fill-rectangle-noff + begin + 0 watch-fll-axis + 1 watch-fll-axis key? + until + key drop + page +; + + +[then] + + + : press ( line$ -- ) type ." , press a key" @@ -550,7 +637,7 @@ pbuf 2+ c@ h# 04 = if \ touch notification event pbuf 3 + c@ 0 do \ per subpacket loop pbuf 4 + i 9 * + >r ( r:addr ) - screen-w r@ w@ - ( x r:addr ) + r@ w@ x>x' ( x r:addr ) r@ wa1+ w@ ( x y r:addr ) r> 4 + c@ 2 rshift setcolor ( x y ) (ev) ( )
