Author: wmb Date: Wed Sep 19 09:06:03 2012 New Revision: 3317 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3317
Log: OLPC - Implemented ?ofw-reflash in security.fth so that the version in /boot/olpc.fth will not be used. This has the effect of extending the rule of "bootfw.zip" must be named "bootfw4.zip" for XO-4 to the unsecure boot domain too.
Modified: cpu/x86/pc/olpc/security.fth
Modified: cpu/x86/pc/olpc/security.fth ============================================================================== --- cpu/x86/pc/olpc/security.fth Wed Sep 19 08:31:04 2012 (r3316) +++ cpu/x86/pc/olpc/security.fth Wed Sep 19 09:06:03 2012 (r3317) @@ -886,13 +886,17 @@ fw#buf 4 + c@ bl = if [char] 0 fw#buf 4 + c! then base @ >r d# 36 base ! fw#buf 5 $number if - show-x - " Invalid firmware version number" .security-failure + secure? if + show-x + " Invalid firmware version number" .security-failure + else + 0 + then then pop-base ; : (fw-version) ( base-adr -- n ) - h# f.ffc7 + ((fw-version)) + signature-offset + 7 + ((fw-version)) ;
\ Returns an integer that is derived from a base-36 decoding @@ -904,8 +908,8 @@
: firmware-up-to-date? ( img$ -- flag ) /flash <> if show-x " Invalid Firmware image" .security-failure then ( adr ) - h# f.ffc7 + ((fw-version)) ( file-version# ) - ofw-version-int ( file-version# rom-version# ) + signature-offset + 7 + ((fw-version)) ( file-version# ) + ofw-version-int ( file-version# rom-version# ) u<= ;
@@ -1025,6 +1029,20 @@ " Reflash returned, unexpectedly" .security-failure ;
+\ Check for new firmware. Used by /boot/olpc.fth. +\ Before calling, set dn-buf to the device, e.g. " int:" +\ and pn-buf to the path, e.g. " \boot" +: ?ofw-reflash ( -- ) + \ It is okay to overwrite cn-buf here, as ?ofw-reflash is used for non-secure + \ boot from olpc.fth. cn-buf is used for the secure boot path. + null$ cn-buf place + " bootfw" bundle-present? if + img$ firmware-up-to-date? 0= if + img$ do-firmware-update + then + then +; + \ Turn off indexed I/O unless the OS is signed with the firmware \ key in addition to the OS key.
