Author: wmb Date: Wed Aug 15 02:09:38 2012 New Revision: 3176 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3176
Log: OLPC ARM - Removed typoed extraneous d# before symbolic names for switch gpios, added gpio properties to 1.75 switches node.
Modified: cpu/arm/olpc/1.75/switches.fth cpu/arm/olpc/cl4/switches.fth
Modified: cpu/arm/olpc/1.75/switches.fth ============================================================================== --- cpu/arm/olpc/1.75/switches.fth Wed Aug 15 00:25:40 2012 (r3175) +++ cpu/arm/olpc/1.75/switches.fth Wed Aug 15 02:09:38 2012 (r3176) @@ -3,6 +3,11 @@
0 0 " 0" " /" begin-package " switches" device-name + +" olpc,xo1.75-switch" +compatible +ebook-mode-gpio# 1 " ebook-gpios" gpio-property +lid-switch-gpio# 1 " lid-gpios" gpio-property + 0 0 reg \ So test-all will run the test : open ( -- okay? ) true ; : close ( -- ) ;
Modified: cpu/arm/olpc/cl4/switches.fth ============================================================================== --- cpu/arm/olpc/cl4/switches.fth Wed Aug 15 00:25:40 2012 (r3175) +++ cpu/arm/olpc/cl4/switches.fth Wed Aug 15 02:09:38 2012 (r3176) @@ -3,11 +3,12 @@
+" switches" device-name + " olpc,xo1.75-switch" +compatible -d# ebook-mode-gpio# 1 " ebook-gpios" gpio-property -d# lid-switch-gpio# 1 " lid-gpios" gpio-property +ebook-mode-gpio# 1 " ebook-gpios" gpio-property +lid-switch-gpio# 1 " lid-gpios" gpio-property
-" switches" device-name 0 0 reg \ So test-all will run the test : open ( -- okay? ) true ; : close ( -- ) ;
