Author: wmb Date: Fri Sep 30 02:15:06 2011 New Revision: 2553 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2553
Log: Libertas driver - trac #11230 - WLAN selftest - added association test that runs if there is an OLPCOFW access point.
Modified: dev/libertas.fth
Modified: dev/libertas.fth ============================================================================== --- dev/libertas.fth Fri Sep 30 02:13:12 2011 (r2552) +++ dev/libertas.fth Fri Sep 30 02:15:06 2011 (r2553) @@ -926,7 +926,7 @@
d# 34 instance buffer: scan-ssid
-0 value scan-type +0 instance value scan-type : active-scan ( -- ) 0 to scan-type ; : passive-scan ( -- ) 1 to scan-type ;
@@ -2088,6 +2088,24 @@
: reset ( -- flag ) reset-nic ;
+: test-association ( -- error? ) + passive-scan + " OLPCOFW" " scan-ssid?" $call-supplicant if + " (do-associate)" $call-supplicant if + \ Success + " target-mac$" $call-supplicant disassociate + true to ssid-reset? + false + else + true + then + else + \ There is no OLPCOFW access point, so we don't try associating + false + then + active-scan +; + : (scan-wifi) ( -- error? ) true to force-open? open @@ -2106,7 +2124,8 @@ true then else ( adr len ) - drop .ssids false + drop .ssids ( ) + test-association ( error? ) then then
