Author: wmb Date: 2009-01-23 21:21:20 +0100 (Fri, 23 Jan 2009) New Revision: 1079
Modified: dev/geode/display/gxfb.fth Log: OLPC - The selftest method for the Geode display driver was using only part of the screen due to a scoping problem with the width and height values.
Modified: dev/geode/display/gxfb.fth =================================================================== --- dev/geode/display/gxfb.fth 2009-01-23 20:00:12 UTC (rev 1078) +++ dev/geode/display/gxfb.fth 2009-01-23 20:21:20 UTC (rev 1079) @@ -5,8 +5,11 @@ headers
-d# 1024 instance value width \ Frame buffer line width -d# 768 instance value height \ Screen height +\ width and height are global instead of instance values because +\ the seltest method needs to get their values in a fresh instance +\ with re-running the open method. +d# 1024 ( instance ) value width \ Frame buffer line width +d# 768 ( instance ) value height \ Screen height d# 16 instance value depth \ Bits per pixel d# 1024 instance value /scanline \ Frame buffer line width
