Author: wmb Date: 2009-01-07 10:14:26 +0100 (Wed, 07 Jan 2009) New Revision: 1067
Modified: cpu/x86/pc/olpc/copynand.fth Log: OLPC trac 9179 - fixed Divide Error in scan-nand examination phase.
Modified: cpu/x86/pc/olpc/copynand.fth =================================================================== --- cpu/x86/pc/olpc/copynand.fth 2009-01-07 09:07:30 UTC (rev 1066) +++ cpu/x86/pc/olpc/copynand.fth 2009-01-07 09:14:26 UTC (rev 1067) @@ -27,7 +27,7 @@ fileih ?dup if 0 to fileih close-dev then ; : close-nand ( -- ) - nandih ?dup if 0 to nandih close-dev 0 to #nand-pages then + nandih ?dup if 0 to nandih close-dev then ; : close-nand-ihs ( -- ) 0 to nanddump-mode? @@ -697,7 +697,7 @@
: slowdump-nand ( -- ) \ The stack is empty at the end of each line unless otherwise noted - #nand-pages 0 do + #nand-pages 0 ?do (cr i >eblock# . load-base i nand-pages/block " read-pages" $call-nand ( #read ) nand-pages/block = if
