Author: wmb Date: Sat Aug 6 00:44:01 2011 New Revision: 2427 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2427
Log: Biosload version: Intel Pineview support, multiplexed I/O, tag file creation, make ega messages optional, better PCI addresses-assigned handling.
Modified: cpu/x86/pc/biosload/devices.fth cpu/x86/pc/biosload/fw.bth
Modified: cpu/x86/pc/biosload/devices.fth ============================================================================== --- cpu/x86/pc/biosload/devices.fth Sat Aug 6 00:41:36 2011 (r2426) +++ cpu/x86/pc/biosload/devices.fth Sat Aug 6 00:44:01 2011 (r2427) @@ -10,6 +10,8 @@ fload ${BP}/dev/pcibus.fth \ Generic PCI bus package
[ifdef] addresses-assigned + 0 0 " addresses-preassigned" property +0 [if] \ Suppress PCI address assignment; use the addresses the BIOS assigned patch false true master-probe patch noop assign-all-addresses prober @@ -21,6 +23,7 @@ patch or-w! my-w! find-fcode? patch 2drop my-w! find-fcode? [then] +[then]
fload ${BP}/cpu/x86/pc/biosload/pcinode.fth \ System-specific words for PCI end-package @@ -249,6 +252,14 @@ devalias screen /display \ Explicit, because it's not probed [then]
+[ifdef] use-pineview +0 0 " 2,0" " /pci" begin-package + " display" name + fload ${BP}/dev/intel/graphics/pineview.fth +end-package +devalias screen /pci/display@2,0 \ Explicit, because it's not probed +[then] + [ifdef] use-ct65550 0 0 " i3b0" " /isa" begin-package fload ${BP}/dev/ct6555x/loadpkg.fth \ Video driver @@ -337,13 +348,19 @@ fload ${BP}/dev/usb2/device/debugport.fth \ ISA COM port driver [else] fload ${BP}/dev/isa/diaguart.fth \ ISA COM port driver -h# 3f8 is uart-base [then]
fload ${BP}/forth/lib/sysuart.fth \ Use UART for key and emit -fload ${BP}/cpu/x86/pc/egauart.fth \ Output also to EGA +[ifndef] no-ega-startup-messages +fload ${BP}/cpu/x86/pc/egauart.fth \ Output also to EGA +[then] + +0 value keyboard-ih +0 value screen-ih + +fload ${BP}/ofw/core/muxdev.fth \ I/O collection/distribution device
-fload ${BP}/cpu/x86/pc/reset.fth \ reset-all +fload ${BP}/cpu/x86/pc/reset.fth \ reset-all
[ifdef] olpc \ true constant lx? \
Modified: cpu/x86/pc/biosload/fw.bth ============================================================================== --- cpu/x86/pc/biosload/fw.bth Sat Aug 6 00:41:36 2011 (r2426) +++ cpu/x86/pc/biosload/fw.bth Sat Aug 6 00:44:01 2011 (r2427) @@ -7,6 +7,8 @@ in: bootsec.hex build-now
+" fw.tag" r/w create-file drop tag-file ! + hex \ ' $report-name is include-hook
@@ -354,8 +356,9 @@
auto-banner? if " Probing" ?type probe-all - " Install console" ?type install-console - ?usb-keyboard + install-mux-io +\ " Install console" ?type install-console +\ ?usb-keyboard banner then
@@ -406,6 +409,8 @@
" dhcp" ' ip-address set-config-string-default
+tag-file @ fclose tag-file off + .( SAVING FW.dic ...) " fw.dic" $save-forth cr
