Author: wmb Date: Thu Dec 13 01:26:17 2012 New Revision: 3490 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3490
Log: OLPC XO-4 - Removed from the panel device node the max-fb-size property that is (hopefully) no longer apropos.
Modified: cpu/arm/olpc/1.75/lcdcfg.fth
Modified: cpu/arm/olpc/1.75/lcdcfg.fth ============================================================================== --- cpu/arm/olpc/1.75/lcdcfg.fth Thu Dec 13 01:23:06 2012 (r3489) +++ cpu/arm/olpc/1.75/lcdcfg.fth Thu Dec 13 01:26:17 2012 (r3490) @@ -19,8 +19,6 @@ " OLPC DCON panel" model : +i encode-int encode+ ;
- d# 4324096 " max-fb-size" integer-property - decimal 0 0 encode-bytes \ xres, yres, refresh, clockhz, left, right, top, bottom, hsync, vsync, flags, widthmm, heightmm @@ -39,7 +37,7 @@ [ifdef] mmp3 h# 20001102 [else] h# 40001102 [then] " clock-divider-regval" integer-property
finish-device -device-end +device-end
[ifdef] has-dcon fload ${BP}/dev/olpc/dcon/mmp2dcon.fth \ DCON control
