Author: wmb Date: 2008-09-03 06:52:06 +0200 (Wed, 03 Sep 2008) New Revision: 919
Added: cpu/x86/pc/olpc/help.fth Modified: cpu/x86/pc/linux.fth cpu/x86/pc/olpc/fw.bth Log: OLPC trac 8280 - set lines/page based on the number of lines on the screen.
Modified: cpu/x86/pc/linux.fth =================================================================== --- cpu/x86/pc/linux.fth 2008-09-02 22:45:08 UTC (rev 918) +++ cpu/x86/pc/linux.fth 2008-09-03 04:52:06 UTC (rev 919) @@ -283,47 +283,6 @@ ." More information: http://firmworks.com/QuickRef.html" cr ;
-d# 34 to default-#lines - -warning @ warning off -: help ( -- ) - blue-letters ." UPDATES:" black-letters mcr - ." flash u:\q2c18.rom Rewrite the firmware from USB key" mcr - ." flash nand:\q2c18.rom Rewrite the firmware from NAND file" mcr - ." copy-nand u:\boot\nand290.img Rewrite the OS on NAND from USB key" mcr - mcr - blue-letters ." DIRECTORY LISTING:" black-letters mcr - ." dir u:\ List USB key root directory" mcr - ." dir u:\boot\ List USB key /boot directory" mcr - ." dir nand:\boot\ List NAND FLASH /boot directory" mcr - ." dir nand:\boot*.rom List .rom files in NAND FLASH /boot directory" mcr - mcr - blue-letters ." BOOTING:" black-letters mcr - ." boot Load the OS from list of default locations" mcr - ." 'printenv boot-device' shows the list" mcr - ." boot <cmdline> Load the OS, passing <cmdline> to kernel" mcr - ." boot u:\boot\vmlinuz Load the OS from a specific location" mcr - mcr - blue-letters ." CONFIGURATION VARIABLES FOR BOOTING:" black-letters mcr - ." boot-device Kernel or boot script path. Example: nand:\boot\olpc.fth" mcr - ." boot-file Default cmdline. Example: console=ttyS0,115200" mcr - ." ramdisk initrd pathname. Example: disk:\boot\initrd.imz" mcr - mcr - blue-letters ." MANAGING CONFIGURATION VARIABLES:" black-letters mcr - ." printenv [ <name> ] Show configuration variables" mcr - ." setenv <name> <value> Set configuration variable" mcr - ." editenv <name> Edit configuration variable" mcr - mcr - blue-letters ." DIAGNOSTICS:" black-letters mcr - ." test <device-name> Test device. Example: test mouse" mcr - ." test-all Test all devices that have test routines" mcr - mcr - ." More information: " - green-letters ." http://wiki.laptop.org/go/OFW_FAQ" black-letters cr -; -warning ! - - \ LICENSE_BEGIN \ Copyright (c) 2006 FirmWorks \
Modified: cpu/x86/pc/olpc/fw.bth =================================================================== --- cpu/x86/pc/olpc/fw.bth 2008-09-02 22:45:08 UTC (rev 918) +++ cpu/x86/pc/olpc/fw.bth 2008-09-03 04:52:06 UTC (rev 919) @@ -314,7 +314,13 @@ vpci-devices-on \ Do this after quieting USB ; ' setup-for-linux to linux-hook +: screen-#lines ( -- n ) + screen-ih 0= if default-#lines exit then + screen-ih package( #lines )package +; +' screen-#lines to lines/page
+fload ${BP}/cpu/x86/pc/olpc/help.fth fload ${BP}/cpu/x86/pc/olpc/gui.fth fload ${BP}/cpu/x86/pc/olpc/suspend.fth \ Suspend/resume setup fload ${BP}/dev/olpc/keyboard/selftest.fth \ Keyboard diagnostic
Added: cpu/x86/pc/olpc/help.fth =================================================================== --- cpu/x86/pc/olpc/help.fth (rev 0) +++ cpu/x86/pc/olpc/help.fth 2008-09-03 04:52:06 UTC (rev 919) @@ -0,0 +1,32 @@ +purpose: Basic help for OLPC OFW + +warning @ warning off +: help ( -- ) + blue-letters ." UPDATES:" black-letters mcr + ." flash u:\q2c18.rom Rewrite the firmware from USB key" mcr + ." flash nand:\q2c18.rom Rewrite the firmware from NAND file" mcr + ." copy-nand u:\boot\nand290.img Rewrite the OS on NAND from USB key" mcr + blue-letters ." DIRECTORY LISTING:" black-letters mcr + ." dir u:\ List USB key root directory" mcr + ." dir u:\boot\ List USB key /boot directory" mcr + ." dir nand:\boot*.rom List .rom files in NAND FLASH /boot directory" mcr + blue-letters ." BOOTING:" black-letters mcr + ." boot Load the OS from list of default locations" mcr + ." 'printenv boot-device' shows the list" mcr + ." boot <cmdline> Load the OS, passing <cmdline> to kernel" mcr + ." boot u:\boot\vmlinuz Load the OS from a specific location" mcr + blue-letters ." CONFIGURATION VARIABLES FOR BOOTING:" black-letters mcr + ." boot-device Kernel or boot script path. Example: nand:\boot\olpc.fth" mcr + ." boot-file Default cmdline. Example: console=ttyS0,115200" mcr + ." ramdisk initrd pathname. Example: disk:\boot\initrd.imz" mcr + blue-letters ." MANAGING CONFIGURATION VARIABLES:" black-letters mcr + ." printenv [ <name> ] Show configuration variables" mcr + ." setenv <name> <value> Set configuration variable" mcr + ." editenv <name> Edit configuration variable" mcr + blue-letters ." DIAGNOSTICS:" black-letters mcr + ." test <device-name> Test device. Example: test mouse" mcr + ." test-all Test all devices that have test routines" mcr + blue-letters ." More information: " black-letters mcr + green-letters ." http://wiki.laptop.org/go/OFW_FAQ" black-letters cr +; +warning !
