Author: wmb Date: Tue Oct 2 02:26:16 2012 New Revision: 3345 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3345
Log: OLPC ARM SDHCI - removed now-redundant SDHCI clock register settings from stand-init.
Modified: cpu/arm/olpc/sdhci.fth
Modified: cpu/arm/olpc/sdhci.fth ============================================================================== --- cpu/arm/olpc/sdhci.fth Fri Sep 28 23:48:00 2012 (r3344) +++ cpu/arm/olpc/sdhci.fth Tue Oct 2 02:26:16 2012 (r3345) @@ -104,9 +104,5 @@ devalias mmc1 /sd/sdhci@d4280800
stand-init: SDHC clocks - h# 41b h# 282854 io! \ SD0 (external SD) clocks, plus set master clock divisor - h# 1b h# 282858 io! \ SD1 (WLAN) clocks - h# 1b h# 2828e8 io! \ SD2 (internal microSD) clocks - h# 70a h# 200104 io! \ Clock gating - h# 70a h# 201104 io! \ Clock gating + h# 400 h# 54 pmua! \ Master SDH clock divisor ;
