Author: wmb Date: Sat Jun 30 00:08:07 2012 New Revision: 3026 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3026
Log: Checked in "slot.fth" file needed by previous checkin.
Added: dev/mmc/sdhci/slot.fth
Added: dev/mmc/sdhci/slot.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ dev/mmc/sdhci/slot.fth Sat Jun 30 00:08:07 2012 (r3026) @@ -0,0 +1,29 @@ +" sdhci" name + +0 " #address-cells" integer-property +0 " #size-cells" integer-property +: open true ; +: close ; + +: r/w-blocks " r/w-blocks" $call-parent ; +: erase-blocks " erase-blocks" $call-parent ; +: fresh-write-blocks-start " fresh-write-blocks-start" $call-parent ; +: r/w-blocks-end " r/w-blocks-end" $call-parent ; +: dma-alloc " dma-alloc" $call-parent ; +: dma-free " dma-free" $call-parent ; +: set-address ( rca -- ) my-unit " set-address" $call-parent ; +: get-address " get-address" $call-parent ; +: attach-card " attach-card" $call-parent ; +: detach-card " detach-card" $call-parent ; +: size " size" $call-parent ; +: show-cid " show-cid" $call-parent ; +: /block " /block" $call-parent ; +: write-protected? " write-protected?" $call-parent ; +: card-inserted? " card-inserted?" $call-parent ; + +: attach-sdio-card " attach-sdio-card" $call-parent ; +: detach-sdio-card " detach-sdio-card" $call-parent ; +: r/w-ioblocks " r/w-ioblocks" $call-parent ; +: io-b@ " io-b@" $call-parent ; +: io-b! " io-b!" $call-parent ; +: io-b!@ " io-b!@" $call-parent ;
