Author: quozl Date: Wed Apr 25 06:53:43 2012 New Revision: 2953 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2953
Log: ext2fs - interpret a zero physical block in the block list of an inode as meaning the block does not exist, OLPC trac #11812
Modified: ofw/fs/ext2fs/layout.fth
Modified: ofw/fs/ext2fs/layout.fth ============================================================================== --- ofw/fs/ext2fs/layout.fth Wed Apr 25 01:31:11 2012 (r2952) +++ ofw/fs/ext2fs/layout.fth Wed Apr 25 06:53:43 2012 (r2953) @@ -71,7 +71,9 @@ >pblk-adr dup 0= if ( 0 ) exit ( -- false ) then ( adr ) - int@ u>d true ( d.physical-block# true ) + int@ dup 0<> if ( u.physical-block# ) + u>d true ( -- d.physical-block# true ) + then ( -- false ) \ there is no physical block ;
