Author: wmb Date: 2009-04-18 21:10:08 +0200 (Sat, 18 Apr 2009) New Revision: 1149
Modified: cpu/x86/pc/olpc/sdtools/sd.fth Log: sdkit - updated addresses to reflect current OLPC usage.
Modified: cpu/x86/pc/olpc/sdtools/sd.fth =================================================================== --- cpu/x86/pc/olpc/sdtools/sd.fth 2009-04-18 19:09:05 UTC (rev 1148) +++ cpu/x86/pc/olpc/sdtools/sd.fth 2009-04-18 19:10:08 UTC (rev 1149) @@ -63,12 +63,26 @@ \needs ec@ fload ecio.fth \needs ec-range fload ecdump.fth
+\ from olpc/addrs.fth +h# fd00.0000 constant fb-pci-base +h# fe00.0000 constant gp-pci-base +h# fe00.4000 constant dc-pci-base +h# fe00.8000 constant vp-pci-base +h# fe00.c000 constant vip-pci-base +h# fe01.0000 constant aes-pci-base +h# fe01.a000 constant ohci-pci-base +h# fe01.b000 constant ehci-pci-base +h# fe02.0000 constant nand-pci-base +h# fe02.4000 constant sd-pci-base +h# fe02.8000 constant camera-pci-base +h# fe02.c000 constant uoc-pci-base + : map-io ( -- ) - h# fe01.0000 h# 4000 mmap to sd-base h# fff0.0000 h# 10.0000 mmap to flash-base - h# fe00.8000 h# 4000 mmap to vp-base - h# fe00.4000 h# 4000 mmap to dc-base - h# fe00.0000 h# 4000 mmap to gp-base + sd-pci-base h# 4000 mmap to sd-base + vp-pci-base h# 4000 mmap to vp-base + dc-pci-base h# 4000 mmap to dc-base + gp-pci-base h# 4000 mmap to gp-base ; map-io
