Author: wmb Date: 2008-12-19 20:06:16 +0100 (Fri, 19 Dec 2008) New Revision: 1036
Modified: forth/wrapper/wrapper.c Log: Tweaks to wrapper.c for compilation on ARM.
Modified: forth/wrapper/wrapper.c =================================================================== --- forth/wrapper/wrapper.c 2008-12-19 07:55:27 UTC (rev 1035) +++ forth/wrapper/wrapper.c 2008-12-19 19:06:16 UTC (rev 1036) @@ -130,7 +130,7 @@ char *host_os = "freebsd"; #endif
-#ifdef HOSTARM +#ifdef __arm__ char *host_cpu = "arm"; #define HOST_LITTLE_ENDIAN #endif @@ -158,7 +158,6 @@
#ifdef ARM char *target_cpu = "arm"; -char *host_cpu = "arm"; #define CPU_MAGIC 0xe1a00000 #define START_OFFSET 8 #endif @@ -937,7 +936,7 @@
#else
-# if defined(HOST_LITTLE_ENDIAN) +# if defined(TARGET_POWERPC) && defined(HOST_LITTLE_ENDIAN) lbflips((long *)&header, sizeof(header)); # endif
@@ -1549,6 +1548,7 @@ 1200, B1200, 1800, B1800, 2400, B2400, 4800, B4800, 9600, B9600, 19200, B19200, 38400, B38400, 57600, B57600, 115200, B115200, +#ifdef B230400 230400, B230400,
#ifdef B4000000 @@ -1558,6 +1558,7 @@ 2500000, B2500000, 3000000, B3000000, 3500000, B3500000, 4000000, B4000000, #endif +#endif -1, -1, };
