Author: wmb Date: 2009-11-14 02:07:52 +0100 (Sat, 14 Nov 2009) New Revision: 1480
Modified: cpu/x86/pc/olpc/via/devices.fth Log: OLPC trac 9489 - the int and ext devaliases were wrong for B3.
Modified: cpu/x86/pc/olpc/via/devices.fth =================================================================== --- cpu/x86/pc/olpc/via/devices.fth 2009-11-14 01:07:09 UTC (rev 1479) +++ cpu/x86/pc/olpc/via/devices.fth 2009-11-14 01:07:52 UTC (rev 1480) @@ -336,7 +336,6 @@ devalias n int devalias ide /ide@0/disk devalias sd /sd/disk@2 -devalias ext /sd/disk@2 devalias net /wlan
\ The "int" devalias is defined in report-disk at runtime, since it @@ -362,9 +361,18 @@ " disk" " /usb/@10,1/disk" ?report-device \ USB 1.1 " disk" " /usb/@10,0/disk" ?report-device \ USB 1.1
- " int" - atest? if " /ide@0/disk" else " /sd/disk@1" then - $devalias + atest? if + " int" " /ide@0/disk" $devalias + " ext" " /sd/disk@2" $devalias + else + board-revision h# d28 < if \ B2 and earlier + " int" " /sd/disk@1" $devalias + " ext" " /sd/disk@2" $devalias + else + " ext" " /sd/disk@1" $devalias + " int" " /sd/disk@3" $devalias + then + then ;
: report-keyboard ( -- )
