Author: wmb Date: 2009-08-01 00:52:11 +0200 (Sat, 01 Aug 2009) New Revision: 1266
Modified: dev/ide/dmaide.fth dev/ide/generic.fth Log: IDE driver - added DMA write support.
Modified: dev/ide/dmaide.fth =================================================================== --- dev/ide/dmaide.fth 2009-07-31 20:05:33 UTC (rev 1265) +++ dev/ide/dmaide.fth 2009-07-31 22:52:11 UTC (rev 1266) @@ -38,7 +38,7 @@ ;
: dma-wait ( -- ) - begin dma-stat@ dup 1 and 0= swap 2 and or until + begin 1 ms dma-stat@ dup 1 and 0= swap 2 and or until ;
\ Sense and clear errors. The bit masked by 04 is read-clear and means @@ -49,30 +49,36 @@
: dma-interrupt? ( -- flag ) dma-stat@ 4 and ;
-: dma-rblock ( dma-adr #blks -- error? ) - /block@ * - set-dma ( ) - dma-cmd@ 1 or dma-cmd! dma-wait dma-cmd@ 1 invert and dma-cmd! - dma-interrupt? if +: dma-begin ( dma-adr #blks direction -- dma-adr phys #blks ) + dma-cmd! ( dma-adr #blks ) + 2dup /block@ * true " dma-map-in" $call-parent swap ( adr phys #blks ) + 2dup /block@ * set-dma ( adr phys #blks ) + dma-cmd@ 1 or dma-cmd! ( adr phys #blks ) +; +: dma-end ( adr phys #blks -- actual# ) + dma-wait 0 dma-cmd! ( adr phys #blks ) + dma-interrupt? if ( adr phys #blks ) r-csr@ drop \ Clear interrupt in drive - dma-stat@ h# f0 and 4 or dma-stat! - then - dma-error? -; + dma-stat@ h# f0 and 4 or dma-stat! ( adr phys #blks ) + then ( adr phys #blks )
-: (drblocks) ( adr #blks -- actual# ) - tuck dma-rblock if drop 0 then + dma-error? if 0 else dup then >r ( adr phys #blks r: actual ) + + /block@ * " dma-map-out" $call-parent ( r: actual ) + + r> ( actual# ) ;
: dma-rblocks ( adr #blks -- actual#blks ) - 2dup /block@ * true " dma-map-in" $call-parent swap ( adr phys #blks ) + 8 dma-begin ( adr phys #blks ) + dma-read-cmd r-csr! ( adr phys #blks ) + dma-end ( actual#blks ) +;
- dma-read-cmd r-csr! - 8 dma-cmd! \ DMA direction for disk read (0 is write) - ['] rblock behavior >r ['] dma-rblock to rblock - 2dup (drblocks) ( adr phys #blks actual#blks ) - r> to rblock - >r /block@ * " dma-map-out" $call-parent r> ( actual#blks ) +: dma-wblocks ( adr #blks -- actual#blks ) + 0 dma-begin ( adr phys #blks ) + dma-write-cmd r-csr! ( adr phys #blks ) + dma-end ( actual#blks ) ;
: vendor-id ( -- w ) my-space " config-w@" $call-parent ; @@ -172,11 +178,13 @@ 4 my-w@ 4 or 4 my-w!
['] dma-rblocks to rblocks + ['] dma-wblocks to wblocks ; ' (open-dma) to open-dma
: (close-dma) ( -- ) ['] pio-rblocks to rblocks + ['] pio-wblocks to wblocks
\ Disable bus mastering 4 my-w@ 4 invert and 4 my-w!
Modified: dev/ide/generic.fth =================================================================== --- dev/ide/generic.fth 2009-07-31 20:05:33 UTC (rev 1265) +++ dev/ide/generic.fth 2009-07-31 22:52:11 UTC (rev 1266) @@ -177,7 +177,8 @@ chip-base io-blk-w! false pio-end-hack ; -: wblocks ( addr #blks -- actual# | error ) + +: pio-wblocks ( addr #blks -- actual# | error ) over >r ( addr #blks ) ( R: addr ) h# 30 r-csr!
@@ -194,6 +195,8 @@ until r> - /block@ / ; +defer wblocks +' pio-wblocks to wblocks
\ Read or write "#blks" blocks starting at "block#" into memory at "addr" \ Input? is true for reading or false for writing.
