Author: wmb Date: Sat Sep 17 00:58:24 2011 New Revision: 2521 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2521
Log: OLPC XO-1.75 - audio selftest - fixed problem with intermittent channel reversal failures.
Modified: cpu/arm/olpc/1.75/sound.fth dev/hdaudio/test.fth
Modified: cpu/arm/olpc/1.75/sound.fth ============================================================================== --- cpu/arm/olpc/1.75/sound.fth Fri Sep 16 23:39:35 2011 (r2520) +++ cpu/arm/olpc/1.75/sound.fth Sat Sep 17 00:58:24 2011 (r2521) @@ -156,7 +156,7 @@ 1 h# 80 adma! \ Enable DMA completion interrupts h# 0081.3020 h# 40 adma! \ 16 bits, pack, fetch next, enable, chain, hold dest, inc src ; -: stop-out-ring ( -- ) h# 100000 h# 40 adma! ; +: stop-out-ring ( -- ) h# 100000 h# 40 adma! 0 h# 80 adma! ;
: make-in-ring ( -- ) in-desc h# 10 + in-bufs sspa-base /audio-buf in-desc set-descriptor @@ -169,6 +169,7 @@ \ h# 0081.3008 h# 44 adma! \ 16 bits, pack, fetch next, enable, chain, inc dest, hold src h# 00a1.31c8 h# 44 adma! \ 16 bits, pack, fetch next, enable, chain, burst32, inc dest, hold src ; +: stop-in-ring ( -- ) h# 100000 h# 44 adma! 0 h# 84 adma! ;
: copy-out ( -- ) my-out-desc >r ( r: desc ) @@ -380,6 +381,7 @@ copy-in ( actual ) repeat ( actual ) disable-sspa-rx ( actual ) + stop-in-ring ( actual ) reset-rx ( actual ) ; : read ( adr len -- actual ) open-in audio-in close-in ; @@ -401,7 +403,9 @@ in-adr0 to in-adr ( ) in-len0 mono? if 2* then to in-len
- ( audio-clock-on ) ( ) \ This will mess up any frequency settings + \ Resetting the clock at this point seems to prevent intermittent channel + \ reversal on reception. + audio-clock-on ( ) \ This will mess up any frequency settings
setup-sspa-tx ( ) setup-sspa-rx ( ) @@ -428,6 +432,9 @@ disable-sspa-rx ( ) disable-sspa-tx ( )
+ stop-in-ring + stop-out-ring + reset-rx reset-tx
@@ -523,8 +530,7 @@ false value force-internal-mic? \ Can't be implemented on XO-1.75 2 value #channels
-\ Unless you do the audio-clock-on, the L/R phase is often wrong -: input-test-settings ( -- ) ( audio-clock-on ) ; +: input-test-settings ( -- ) ; : output-test-settings ( -- ) ;
d# -1 constant case-test-volume
Modified: dev/hdaudio/test.fth ============================================================================== --- dev/hdaudio/test.fth Fri Sep 16 23:39:35 2011 (r2520) +++ dev/hdaudio/test.fth Sat Sep 17 00:58:24 2011 (r2521) @@ -183,19 +183,25 @@ instructions-done then ; -\ Returns failure by throwing -: automatic-test ( -- ) - analysis-parameters " set-analysis-parameters" $call-analyzer +: acoustic-test ( -- ) disconnect-loopback \ Not for 1.5; it can test internal while loopback is connected " smt-test?" evaluate if test-with-fixture throw else test-with-case throw then +; +: loopback-test ( -- ) connect-loopback test-with-loopback throw disconnect-loopback ; +\ Returns failure by throwing +: automatic-test ( -- ) + analysis-parameters " set-analysis-parameters" $call-analyzer + acoustic-test + loopback-test +; : selftest ( -- error? ) diagnostic-mode? if open 0= if ." Failed to open /audio" cr true exit then
