Author: wmb Date: Thu Jul 15 20:27:57 2010 New Revision: 1880 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1880
Log: Added sparse.c and sparseosfile.fth to svn. They are tools that can be loaded as needed to work on large but sparsely-populated disk images without using up huge amounts of disk space on the host.
Added: ofw/core/sparse.c ofw/core/sparseosfile.fth
Added: ofw/core/sparse.c ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ ofw/core/sparse.c Thu Jul 15 20:27:57 2010 (r1880) @@ -0,0 +1,47 @@ +// Create a sparse disk image file that can be accessed from OFW +// running under Linux using /sparseosfile, after loading sparseosfile.fth +#include <unistd.h> +#include <sys/stat.h> +#include <fcntl.h> + +#define BLKLEN 4096 +char buf[BLKLEN]; +int blen = BLKLEN; + +int allzero(char *buf, size_t len) +{ + long *p = (long *)buf; + len /= sizeof(long); + while (len--) + if(*p++) + return 0; + return 1; +} + +int blockmap[10000]; + +main(int argc, char **argv) +{ + int abs_blockno = 0; + int rel_blockno = 0; + int outfile; + + outfile = creat("outfile", 0666); + if (outfile < 0) { + perror("sparse"); + (void)exit(1); + } + + while(read(0, buf, BLKLEN) == BLKLEN) { + if (!allzero(buf, BLKLEN)) { + write(outfile, buf, BLKLEN); + blockmap[rel_blockno++] = abs_blockno; + } + abs_blockno++; + } + write(outfile, blockmap, rel_blockno*sizeof(int)); + write(outfile, &rel_blockno, sizeof(int)); + write(outfile, &abs_blockno, sizeof(int)); + write(outfile, &blen, sizeof(int)); + close(outfile); +}
Added: ofw/core/sparseosfile.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ ofw/core/sparseosfile.fth Thu Jul 15 20:27:57 2010 (r1880) @@ -0,0 +1,313 @@ +purpose: Device tree node that accesses a host system file +\ See license at end of file + +\ Creates a device node named "/sparsefile", of device-type "block", which +\ accesses an operating system file named by its first argument. That +\ file contains a verbatim disk image in the following sparse format: +\ +\ Images: N block images +\ Map: N integers indicating the block number of the corresponding block image +\ N: integer denoting N +\ Max: integer denoting the maximum block number for the virtual disk +\ BlockSize: integer denoting the length of each block image + +\ Backslash () characters in the file name are translated to +\ the underlying operating system's directory delimiter. +\ Example: dir /osfile:\dev\rfd0,\boot\test.fth +\ Example: dir /osfile:\home\wmb\fs.img,\boot\test.fth +\ As an alternative to supplying the disk image filename in the device +\ specifier, you can set "osfile$" to return the name. This is +\ helpful for cases where the image filename would interfere with +\ the parsing of later parts of the device specifier. +\ Example: +\ dev /osfile +\ : disk-image$ " /tmp/disk.img" ; +\ ' disk-image$ to osfile$ +\ dend +\ dir /osfile:\boot\test.fth +\ When using the "osfile$" method, you can use either backslash () or +\ the system's native delimiter in the disk image filename. When using +\ the device specifier argument method, you must use backslash, because +\ forward slash delimits major device tree components in a device specifier. + +dev / +\ : open true ; : close ; + +new-device +" sparsefile" device-name +also +defer sparsefile$ ' null$ to sparsefile$ +0 value file# + +\ The deblocker converts a block/record-oriented interface to a byte-oriented +\ interface, using internal buffering. Disk and tape devices are usually +\ block or record oriented, but the Open Firmware external interface is +\ byte-oriented, in order to be independent of particular device block sizes. + +0 value deblocker +: init-deblocker ( -- okay? ) + " " " deblocker" $open-package is deblocker + deblocker if + true + else + ." Can't open deblocker package" cr false + then +; + +0 instance value label-package +0 instance value offset-low +0 instance value offset-high + +: init-label-package ( adr len -- okay? ) + 0 is offset-high 0 is offset-low +\ iso9660-file-system + " disk-label" $open-package is label-package + label-package if + 0 0 " offset" label-package $call-method is offset-high is offset-low + true + else + ." Can't open disk label package" cr false + then +; +: convert/ ( filename$ -- ) + bounds ?do + i c@ [char] \ = if [char] / i c! then + loop +; +: $fopen ( adr len -- fd ) $cstr 2 swap 8 syscall 2drop retval ; +: do-seek ( offset whence -- error? ) swap file# _lseek nip ; +: do-write ( adr len -- error? ) + file# ['] _fwrite catch if 3drop true else drop false then +; +: do-read ( adr len -- error? ) + file# ['] _fread catch if 3drop true else drop false then +; + +0 value #block-map +0 value block-map +0 value #blocks +0 value #active-blocks +0 value block-size +d# 12 buffer: params +: parse-sparse ( -- error? ) + 3 /n* negate 2 do-seek if true exit then + params 3 /n* do-read if true exit then + params @ to #active-blocks + params na1+ @ to #blocks + params 2 na+ @ to block-size + #active-blocks d# 1024 + to #block-map + #block-map /n* alloc-mem to block-map + #active-blocks /n* negate 3 /n* - 2 do-seek if true exit then + block-map #active-blocks /n* do-read if true exit then + false +; +: save-block-map ( -- ) + #active-blocks block-size * 0 do-seek if exit then ( ) + block-map #active-blocks /n* do-write if exit then ( ) + #active-blocks params ! + #blocks params na1+ ! + block-size params 2 na+ ! + params 3 /n* do-write drop +; + +0 value open-count +: open ( -- flag ) + my-args ( arg$ ) + sparsefile$ dup 0= if ( arg$ null$ ) + 2drop ( arg$ ) + ascii , left-parse-string ( arg$' img-filename$ ) + then ( arg$ img-filename$ ) + + open-count if ( arg$ img-filename$ ) + 2drop ( arg$ ) + else ( arg$ img-filename$ ) + 2dup convert/ ( arg$ img-filename$ ) + $fopen to file# ( arg$ ) + file# 0< if 2drop false exit then ( arg$ ) + + parse-sparse if 2drop false exit then ( arg$ ) + + init-deblocker 0= if false exit then ( arg$ ) + then ( arg$ ) + + init-label-package dup 0= if ( flag ) + open-count 0= if ( flag ) + deblocker close-package ( false ) + file# d# 16 syscall drop ( false ) + then ( flag ) + then ( flag ) + + dup if ( flag ) + open-count 1+ to open-count ( flag ) + then ( flag ) +; +[ifndef] lfind +[ifdef] 386-assembler + code lfind ( sought adr len -- false | index true ) + cx pop ( cx: len ) + bx pop ( bx: adr ) + dx pop ( dx: sought ) + si push + bx si mov ( si: adr ) + 2 # cx shr ( cx: longword count ) + begin + ax lods + ax dx cmp = if + bx si sub + 2 # si shr + si dec + si 0 [sp] xchg + + ax ax xor + ax dec + ax push + next + then + loopa + si pop \ Restore si + ax ax xor + ax push + c; +[then] +[ifndef] lfind + : lfind ( sought adr len -- false | index true ) + over >r ( sought adr len r: adr ) + over + search if ( loc r: adr ) + r> - /n / true ( index true ) + else ( r: adr ) + r> drop false ( false ) + then ( false | index true ) + ; +[then] +[then] +: >block-index ( block# -- ) + block-map #active-blocks /n* lfind +; +: read-stored-block ( adr index -- error? ) + block-size * 0 do-seek if drop true exit then ( adr ) + block-size do-read if true exit then ( ) + false +; + +: read-block ( adr block# -- error? ) +." R " dup .x + dup #blocks >= if 2drop true exit then + + >block-index if ( adr index ) +." I " dup . cr + read-stored-block ( error? ) + else ( adr ) +." Z" cr + block-size erase ( ) + false ( error? ) + then +; + +: read-blocks ( adr block# #blocks -- actual#blocks ) + -rot 2 pick ( #blocks adr block# ) + 0 do ( #blocks adr block# ) + 2dup read-block if ( #blocks adr block# ) + 3drop i unloop exit ( -- actual#blocks ) + then ( #blocks adr block# ) + swap block-size + swap 1+ ( #blocks adr' block#' ) + loop ( #blocks adr block# ) + 2drop ( actual#blocks ) +; + +: resize-block-map ( -- error? ) + block-map #block-map d# 1024 + /n* resize if ( buf-adr ) + drop true exit ( -- error? ) + then ( buf-adr ) + to block-map ( ) + #block-map d# 1024 + to #block-map ( ) + false ( error? ) +; +: write-stored-block ( adr index -- error? ) + block-size * 0 do-seek if drop true exit then ( adr ) + block-size do-write if true exit then ( ) + false +; + +: write-new-block ( adr block# -- error? ) + #active-blocks #block-map >= if ( adr block# ) + resize-block-map if 2drop true exit then ( adr block# ) + then ( adr block# ) + swap #active-blocks write-stored-block if ( block# ) + drop true exit ( -- error? ) + then ( block# ) + block-map #active-blocks na+ ! ( ) + #active-blocks 1+ to #active-blocks ( ) + false ( error? ) +; + +: write-block ( adr block# -- error? ) +." W " dup .x + dup #blocks >= if ( adr block# ) + 2drop true exit ( -- error? ) + then ( adr block# ) + + dup >block-index if ( adr block# index ) +." I " dup .x cr + nip write-stored-block ( error? ) + else ( adr block# ) +." N" cr + write-new-block ( error? ) + then ( error? ) +; + +: write-blocks ( adr block# #blocks -- actual#blocks ) + -rot 2 pick ( #blocks adr block# ) + 0 do ( #blocks adr block# ) + 2dup write-block if ( #blocks adr block# ) + 3drop i unloop exit ( -- actual#blocks ) + then ( #blocks adr block# ) + swap block-size + swap 1+ ( #blocks adr' block#' ) + loop ( #blocks adr block# ) + 2drop ( actual#blocks ) +; + +: close ( -- ) + open-count dup 1- 0 max to open-count ( prev-open-count ) + label-package close-package ( prev-open-count ) + 1 = if ( ) + deblocker close-package ( ) + save-block-map ( ) + file# d# 16 syscall drop ( ) + then ( ) +; + +: dma-alloc ( size -- adr ) alloc-mem ; +: dma-free ( adr size -- ) free-mem ; +: max-transfer ( -- n ) block-size ; + +: seek ( offset.low offset.high -- okay? ) + offset-low offset-high d+ " seek" deblocker $call-method +; +: read ( addr len -- actual-len ) " read" deblocker $call-method ; +: write ( addr len -- actual-len ) " write" deblocker $call-method ; +finish-device +device-end + +\ LICENSE_BEGIN +\ Copyright (c) 2007 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
