Author: quozl Date: Fri Aug 17 06:11:00 2012 New Revision: 3189 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3189
Log: OLPC - libertas antenna test, translate baseband processor register antenna numbers to the same numbering as used by the user interface.
Modified: dev/libertas.fth
Modified: dev/libertas.fth ============================================================================== --- dev/libertas.fth Fri Aug 17 05:53:07 2012 (r3188) +++ dev/libertas.fth Fri Aug 17 06:11:00 2012 (r3189) @@ -2203,8 +2203,8 @@ : .rx-antenna ( antenna -- ) 6 rshift case - b# 00 of ." 0" endof - b# 01 of ." 1" endof + b# 00 of ." 1" endof + b# 01 of ." 2" endof b# 10 of ." d" endof \ diversity b# 11 of ." ?" endof endcase @@ -2213,8 +2213,8 @@ : .tx-antenna ( antenna -- ) 6 rshift case - b# 00 of ." 0" endof - b# 01 of ." 1" endof + b# 00 of ." 1" endof + b# 01 of ." 2" endof b# 10 of ." r" endof \ same antenna as receive antenna b# 11 of ." ?" endof endcase
