Author: pgf Date: Fri Aug 31 00:10:03 2012 New Revision: 3253 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3253
Log: apbc.fth: add undocumented thermal clocks
there are 4 sensors, each with their own clock
Modified: cpu/arm/mmp2/apbc.fth
Modified: cpu/arm/mmp2/apbc.fth ============================================================================== --- cpu/arm/mmp2/apbc.fth Fri Aug 31 00:05:00 2012 (r3252) +++ cpu/arm/mmp2/apbc.fth Fri Aug 31 00:10:03 2012 (r3253) @@ -45,6 +45,9 @@ " RIPC" +string \ 33 " THSENS1" +string \ 34 " CORESIGHT" +string \ 35 +" THSENS2" +string \ 36 +" THSENS3" +string \ 37 +" THSENS4" +string \ 38 " clock-output-names" property
: +int encode-int encode+ ; @@ -87,6 +90,9 @@ h# 8c +int h# 77 +int h# 3 +int d# 26,000,000 +int \ 33 RIPC h# 90 +int h# 77 +int h# 3 +int d# 26,000,000 +int \ 34 THSENS1 h# 94 +int h# 7 +int h# 3 +int d# 26,000,000 +int \ 35 CORESIGHT +h# 98 +int h# 77 +int h# 3 +int d# 26,000,000 +int \ 36 THSENS2 +h# 9c +int h# 77 +int h# 3 +int d# 26,000,000 +int \ 37 THSENS3 +h# a0 +int h# 77 +int h# 3 +int d# 26,000,000 +int \ 38 THSENS4 " clock-enable-registers" property
: on/off ( on? clock# -- )
