Author: wmb Date: 2009-08-21 11:25:46 +0200 (Fri, 21 Aug 2009) New Revision: 1313
Modified: cpu/x86/pc/olpc/security.fth cpu/x86/pc/olpc/via/devices.fth cpu/x86/pc/olpc/via/fw.bth cpu/x86/pc/olpc/via/usb.fth Log: Via - fixed devalias creation.
Modified: cpu/x86/pc/olpc/security.fth =================================================================== --- cpu/x86/pc/olpc/security.fth 2009-08-20 17:14:17 UTC (rev 1312) +++ cpu/x86/pc/olpc/security.fth 2009-08-21 09:25:46 UTC (rev 1313) @@ -914,7 +914,7 @@ set-alternate
\ button-rotate game-key? if show-warnings then - show-child +\ show-child
button-check game-key? if unfreeze visible banner
Modified: cpu/x86/pc/olpc/via/devices.fth =================================================================== --- cpu/x86/pc/olpc/via/devices.fth 2009-08-20 17:14:17 UTC (rev 1312) +++ cpu/x86/pc/olpc/via/devices.fth 2009-08-21 09:25:46 UTC (rev 1313) @@ -124,12 +124,6 @@ \ We don't need a serial selftest because the serial port is internal only \ and the selftest turns off the diag device dev /serial warning @ warning off : selftest false ; warning ! device-end -devalias com1 /isa/serial@i3f8:115200 -devalias mouse /isa/8042/mouse -devalias d disk -devalias n nand -devalias sd /sd/disk -devalias c /ide@0/disk
[ifndef] demo-board .( Removing ctlr-selftest from 8042 open !!!) cr @@ -196,40 +190,6 @@ ; [then]
-\ Create the alias unless it already exists -: $?devalias ( alias$ value$ -- ) - 2over not-alias? if $devalias exit then ( alias$ value$ alias$ ) - 2drop 4drop -; - -: report-disk ( -- ) - " /usb/disk" locate-device 0= if - drop - " disk" " /usb/disk" $devalias - exit - then - " /usb@f,4/disk" locate-device 0= if - ." Found USB 1.1 disk!" cr - drop - " disk" " /usb@f,4/disk" $devalias - exit - then -; - -: report-keyboard ( -- ) - " /usb@f,4/keyboard" locate-device 0= if - drop - " keyboard" " /usb@f,4/keyboard" $devalias - exit - then - - \ In case the keyboard is behind a USB 2 hub - " /usb@f,5/keyboard" locate-device 0= if - drop - " keyboard" " /usb@f,5/keyboard" $devalias - then -; - fload ${BP}/cpu/x86/inoutstr.fth \ Multiple I/O port read/write fload ${BP}/dev/isa/diaguart.fth \ ISA COM port driver \ : inituarts ascii G uemit ascii o uemit ; \ They are already on @@ -344,6 +304,51 @@ ; warning !
+devalias com1 /isa/serial@i3f8:115200 +devalias mouse /isa/8042/mouse +devalias c int +devalias d disk +devalias n int +devalias ide /ide@0/disk +devalias sd /sd/disk@2 +devalias ext /sd/disk@2 + +\ The "int" devalias is defined in report-disk at runtime, since it +\ varies between A-test and later boards. + +\ Create the alias unless it already exists +: $?devalias ( alias$ value$ -- ) + 2over not-alias? if $devalias exit then ( alias$ value$ alias$ ) + 2drop 4drop +; + +: ?report-device ( alias$ pathname$ -- ) + 2dup locate-device 0= if ( alias$ pathname$ phandle ) + drop ( alias$ pathname$ ) + 2over 2over $?devalias ( alias$ pathname$ ) + then ( alias$ pathname$ ) + 4drop ( ) +; + +: report-disk ( -- ) + " disk" " /usb/@10,4/disk" ?report-device \ USB 2 + " disk" " /usb/@10,2/disk" ?report-device \ USB 1.1 + " disk" " /usb/@10,1/disk" ?report-device \ USB 1.1 + " disk" " /usb/@10,0/disk" ?report-device \ USB 1.1 + + " int" + atest? if " /ide@0/disk" else " /sd/disk@1" then + $devalias +; + +: report-keyboard ( -- ) + \ Prefer direct-attached + " usb-keyboard" " /usb@10,2/keyboard" ?report-device \ USB 1.1 + " usb-keyboard" " /usb@10,1/keyboard" ?report-device \ USB 1.1 + " usb-keyboard" " /usb@10,0/keyboard" ?report-device \ USB 1.1 + " usb-keyboard" " /usb@10,4/keyboard" ?report-device \ USB 2 (keyboard behind a hub) +; + [ifdef] Later \ Add support for DC-couple microphone input [then]
Modified: cpu/x86/pc/olpc/via/fw.bth =================================================================== --- cpu/x86/pc/olpc/via/fw.bth 2009-08-20 17:14:17 UTC (rev 1312) +++ cpu/x86/pc/olpc/via/fw.bth 2009-08-21 09:25:46 UTC (rev 1313) @@ -330,6 +330,7 @@ : text-on ( -- ) text-on? 0= if screen-ih add-mux + cursor-on true to text-on? then ; @@ -380,7 +381,7 @@
fload ${BP}/cpu/x86/pc/olpc/rtcwake.fth
-" /xp u:\boot\olpc.fth sd:\boot\olpc.fth c:\boot\olpc.fth nand:\boot\olpc.fth /prober /usb/ethernet /usb/wlan" +" /xp u:\boot\olpc.fth ext:\boot\olpc.fth int:\boot\olpc.fth /prober /usb/ethernet /usb/wlan" ' boot-device set-config-string-default
\needs ramdisk " " d# 128 config-string ramdisk @@ -531,8 +532,10 @@ then
install-mux-io + cursor-off true to text-on?
+ " //null" open-dev to null-ih \ For text-off state
?gui-banner @@ -567,7 +570,7 @@ [then] then ( in-factory? ) if ( ) - " /prober /usb/ethernet disk:\boot\olpc.fth nand:\boot\olpc.fth /xp sd:\boot\olpc.fth /usb/wlan" + " /prober /usb/ethernet disk:\boot\olpc.fth int:\boot\olpc.fth /xp ext:\boot\olpc.fth /usb/wlan" to boot-device then ( ) ; @@ -636,11 +639,16 @@ " probe-" do-drop-in
probe-pci + show-child sound ?games + \ XXX we should put up the splash screen here + ['] false to interrupt-auto-boot? probe-usb " probe+" do-drop-in + report-disk + report-keyboard
setup-smbios \ Must be done after build-date is defined via do-drop-in
Modified: cpu/x86/pc/olpc/via/usb.fth =================================================================== --- cpu/x86/pc/olpc/via/usb.fth 2009-08-20 17:14:17 UTC (rev 1312) +++ cpu/x86/pc/olpc/via/usb.fth 2009-08-21 09:25:46 UTC (rev 1313) @@ -53,10 +53,10 @@ alias p2 probe-usb
: ?usb-keyboard ( -- ) - " keyboard" expand-alias if ( devspec$ ) - drop " /usb" comp 0= if ( ) + " usb-keyboard" expand-alias if ( devspec$ ) + drop " /usb" comp 0= if ( ) red-letters ." Using USB keyboard." cr black-letters - " keyboard" open-dev add-mux + " usb-keyboard" open-dev add-mux exit then then
