Author: pgf Date: Fri Aug 31 00:10:06 2012 New Revision: 3254 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3254
Log: thermal.fth: add device-tree support for thermal driver
Modified: cpu/arm/mmp3/thermal.fth
Modified: cpu/arm/mmp3/thermal.fth ============================================================================== --- cpu/arm/mmp3/thermal.fth Fri Aug 31 00:10:03 2012 (r3253) +++ cpu/arm/mmp3/thermal.fth Fri Aug 31 00:10:06 2012 (r3254) @@ -1,6 +1,30 @@ \ See license at end of file purpose: Driver for the MMP3 thermal sensor
+0 0 " d403b000" " /" begin-package + " thermal" name + " marvell,mmp3-thermal" +compatible + my-address my-space h# 1000 reg + + d# 11 encode-int " interrupts" property + " /interrupt-controller/interrupt-controller@188" encode-phandle " interrupt-parent" property + + " /apbc" encode-phandle + 34 encode-int encode+ + " /apbc" encode-phandle encode+ + 36 encode-int encode+ + " /apbc" encode-phandle encode+ + 37 encode-int encode+ + " /apbc" encode-phandle encode+ + 38 encode-int encode+ " clocks" property + + " THSENS1" encode-string + " THSENS2" encode-string encode+ + " THSENS3" encode-string encode+ + " THSENS4" encode-string encode+ " clock-names" property + +end-package + \ FIXME: characterise the observations using an IR thermometer, \ because the datasheet and the registers manual disagree on \ interpretation of these gray code values.
