Author: wmb Date: Wed Aug 11 06:54:43 2010 New Revision: 1927 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1927
Log: ARM - separated the staticly linked armforth.static from the native wrapper to make things work more smoothly when compiling natively.
Added: cpu/arm/Linux/armforth.static - copied unchanged from r1926, cpu/arm/Linux/armforth Deleted: cpu/arm/Linux/armforth Modified: cpu/arm/Linux/Makefile cpu/x86/Linux/armforth
Modified: cpu/arm/Linux/Makefile ============================================================================== --- cpu/arm/Linux/Makefile Wed Aug 11 06:39:19 2010 (r1926) +++ cpu/arm/Linux/Makefile Wed Aug 11 06:54:43 2010 (r1927) @@ -3,7 +3,6 @@ BP=../../..
CFLAGS = -DARM -mlittle-endian -LFLAGS = -static
WRTAIL = forth/wrapper WRDIR = ${BP}/${WRTAIL} @@ -26,6 +25,11 @@ armforth: ${OBJS} ${CC} ${CFLAGS} ${LFLAGS} -o $@ ${OBJS}
+# This staticly-linked wrapper is used by cpu/x86/Linux/armforth for cross-building +# with the help of QEMU. +armforth.static: ${OBJS} + ${CC} ${CFLAGS} ${LFLAGS} -static -o $@ ${OBJS} + %.o: ${WRDIR}/%.c ${CC} -c ${CFLAGS} $< -o $@
Copied: cpu/arm/Linux/armforth.static (from r1926, cpu/arm/Linux/armforth) ============================================================================== Binary file (source and/or target). No diff available.
Modified: cpu/x86/Linux/armforth ============================================================================== --- cpu/x86/Linux/armforth Wed Aug 11 06:39:19 2010 (r1926) +++ cpu/x86/Linux/armforth Wed Aug 11 06:54:43 2010 (r1927) @@ -1,2 +1,2 @@ #!/bin/sh -qemu-arm ${BP}/cpu/arm/Linux/forth $* +qemu-arm ${BP}/cpu/arm/Linux/armforth.static $*
