Author: wmb Date: Thu Jun 2 04:23:12 2011 New Revision: 2239 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2239
Log: OLPC XO-1.75 test menu - test /usb/hub instead of /usb.
Modified: cpu/arm/olpc/1.75/mfgtest.fth
Modified: cpu/arm/olpc/1.75/mfgtest.fth ============================================================================== --- cpu/arm/olpc/1.75/mfgtest.fth Thu Jun 2 04:17:39 2011 (r2238) +++ cpu/arm/olpc/1.75/mfgtest.fth Thu Jun 2 04:23:12 2011 (r2239) @@ -127,7 +127,7 @@ : battery-item ( -- ) " /battery" mfg-test-dev ; : spiflash-item ( -- ) " /flash" mfg-test-dev ; : memory-item ( -- ) " /memory" mfg-test-dev ; -: usb-item ( -- ) " /usb" mfg-test-dev ; +: usb-item ( -- ) " /usb/hub" mfg-test-dev ; : int-sd-item ( -- ) " int:0" mfg-test-dev ; : ext-sd-item ( -- ) " ext:0" mfg-test-dev ; : rtc-item ( -- ) " /rtc" mfg-test-dev ;
