Author: quozl Date: Tue Oct 18 06:54:24 2011 New Revision: 2624 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2624
Log: OLPC ext2, enhance tests, with md5sum comparison and file content comparison
Modified: ofw/fs/ext2fs/ext2test.fth
Modified: ofw/fs/ext2fs/ext2test.fth ============================================================================== --- ofw/fs/ext2fs/ext2test.fth Sun Oct 16 03:21:46 2011 (r2623) +++ ofw/fs/ext2fs/ext2test.fth Tue Oct 18 06:54:24 2011 (r2624) @@ -4,25 +4,92 @@ \ Exercises several OFW features on an ext2 filesystem on a USB stick \ see associated test.sh
+[ifndef] $md5sum-file +: $md5sum-file ( prefix$ filename$ -- ) + \ Read file into memory and compute its MD5 hash + 2dup $read-file abort" Read error" ( prefix$ filename$ adr len ) + 2dup $md5digest1 ( prefix$ filename$ adr len md5$ ) + 2swap free-mem ( prefix$ filename$ md5$ ) + + \ Write the hash and the filename in the same format as + \ the output of the Linux "md5sum" command. prefix$ should + \ be " *" to match the output of "md5sum -b" and " " + \ to match the output of "md5sum" without -b. + + \ Output MD5 in lower case ASCII hex + push-hex ( prefix$ filename$ md5$ ) + bounds ?do ( prefix$ filename$ ) + i c@ <# u# u# u#> type + loop ( prefix$ filename$ ) + pop-base ( prefix$ filename$ ) + + \ ... followed by " filename" or " *filename" + ." " ( prefix$ filename$ ) + 2swap type ( filename$ ) + type ( ) + cr +; + +: md5sum ( "file" -- ) + " " safe-parse-word $md5sum-file +; +[then] + +0 value a-adr +0 value a-len +0 value b-adr +0 value b-len + +: (read-files) ( "a" "b" -- ) + safe-parse-word $read-file abort" Read error" + to b-len to b-adr + safe-parse-word $read-file abort" Read error" + to a-len to a-adr +; + +: (compare-files) ( -- equal-flag ) + a-len b-len = if + a-adr b-adr b-len comp 0= + else + false + then +; + +: (free-files) + a-adr a-len free-mem + b-adr b-len free-mem +; + +: compare-files + (read-files) (compare-files) (free-files) + if ." files equal" cr else ." files differ" cr then +; + +: compare-md5-files + (read-files) + d# 32 to a-len + d# 32 to b-len + (compare-files) + (free-files) + if ." checksums equal" cr else ." checksums differ" cr then +; + visible no-page -start-logging
.( test.fth ticket #6210 ofw ext2 filesystem tests ) cr
-show-aborts on - .( test 0001 define u: ) cr volume: u:
.( test 0002 reference u: ) cr u:
-\ .( test 0003 directory ) cr -\ dir +.( test 0003 directory ) cr +dir
-\ .( test 0004 directory by name ) cr -\ dir *.fth +.( test 0004 directory by name ) cr +dir boot*.fth
.( test 0005 chdir down ) cr chdir directory @@ -56,6 +123,7 @@
.( test 0015 copy a file ) cr copy u:\hello-world u:\copy +.( ) compare-files u:\hello-world u:\copy
.( test 0016 display the copy ) cr more u:\copy @@ -69,41 +137,61 @@ .( test 0019 delete a non-existent file ) cr del u:\vapour
-: load-file ( "devspec" -- adr len ) - safe-parse-word - open-dev dup 0= abort" Can't open it" ( ih ) - >r ( r: ih ) - load-base " load" r@ $call-method ( len r: ih ) - r> close-dev ( len ) - load-base swap -; - -: calculate-md5 ( adr len -- adr len ) - $md5digest1 ; - -: print-md5 ( adr len -- ) - bounds ?do i c@ (.2) type loop space ; - -: md5sum ( "devspec" -- ) load-file calculate-md5 print-md5 ; - .( test 0020 calculate md5sum of a test file ) cr -md5sum u:\hello-world cr +.( ) md5sum u:\hello-world
.( test 0021 calculate md5sum of a test file and save to a file ) cr -del u:\hello-world.md5 -load-file u:\hello-world calculate-md5 to-file u:\hello-world.md5 print-md5 +del u:\tmp.md5 +to-file u:\tmp.md5 md5sum u:\hello-world +.( ) compare-md5-files u:\tmp.md5 u:\hello-world.md5 +del u:\tmp.md5
.( test 0022 dump forth dictionary to file ) cr +to-file u:\words.txt words +to-file u:\words.tmp words +.( ) compare-files u:\words.txt u:\words.tmp del u:\words.txt -to-file u:\words.txt words +del u:\words.tmp + +.( test 0023 glob file copy ) cr
-\ reference: forth/lib/tofile.fth -\ to-file u:\words words -\ append-to-file u:\words words - -.( done ) cr -save-log u:\ofw.log -stop-logging +.( create input files ... ) +.( a ) to-file u:\a.tst cr +.( b ) to-file u:\b.tst cr +.( c ) to-file u:\c.tst cr +.( d ) to-file u:\d.tst cr +.( e ) to-file u:\e.tst cr +.( f ) to-file u:\f.tst cr +cr + +.( create directory ... ) +mkdir u:\j +.( ok ) cr + +.( copy ... ) +copy u:*.tst u:\j +.( ok ) cr + +.( delete copies ... ) +.( a ) del u:\j\a.tst +.( b ) del u:\j\b.tst +.( c ) del u:\j\c.tst +.( d ) del u:\j\d.tst +.( e ) del u:\j\e.tst +.( f ) del u:\j\f.tst +.( ok ) cr + +.( delete directory ... ) +rmdir u:\j +.( ok ) cr + +.( delete input files ) +.( a ) del u:\a.tst +.( b ) del u:\b.tst +.( c ) del u:\c.tst +.( d ) del u:\d.tst +.( e ) del u:\e.tst +.( f ) del u:\f.tst +.( ok ) cr
-\ .( boot ) cr -\ boot n:\boot\olpc.fth +.( test complete ) cr
