Author: wmb Date: Tue Aug 9 20:33:10 2011 New Revision: 2451 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2451
Log: Alex - enabled timestamp counter and related timing words.
Modified: cpu/x86/pc/alex/config.fth cpu/x86/pc/alex/devices.fth cpu/x86/pc/alex/fw.bth
Modified: cpu/x86/pc/alex/config.fth ============================================================================== --- cpu/x86/pc/alex/config.fth Tue Aug 9 20:32:13 2011 (r2450) +++ cpu/x86/pc/alex/config.fth Tue Aug 9 20:33:10 2011 (r2451) @@ -7,6 +7,9 @@ create coreboot-qemu create debug-startup
+create use-timestamp-counter +create use-tsc-timing + create serial-console
\ In virtual mode, OFW runs with the MMU on. The advantages are
Modified: cpu/x86/pc/alex/devices.fth ============================================================================== --- cpu/x86/pc/alex/devices.fth Tue Aug 9 20:32:13 2011 (r2450) +++ cpu/x86/pc/alex/devices.fth Tue Aug 9 20:33:10 2011 (r2451) @@ -16,19 +16,13 @@
fload ${BP}/dev/pciprobe.fth \ Generic PCI probing
-[ifdef] use-timestamp-counter -\ Use the CPU chip's Time Stamp Counter for timing; it does just what we want +\ Use the CPU chip's Time Stamp Counter for timing fload ${BP}/cpu/x86/tsc.fth -[then]
0 0 " " " /" begin-package fload ${BP}/cpu/x86/pc/isabus.fth \ ISA Bus Bridge under root node end-package
-[ifndef] use-timestamp-counter -fload ${BP}/cpu/x86/pc/getms.fth -[then] - dev /interrupt-controller h# 20 to vector-base0 h# 28 to vector-base1 @@ -95,9 +89,7 @@ fload ${BP}/dev/pci/isaall.fth devalias mouse /isa/8042/mouse
-[ifdef] use-timestamp-counter fload ${BP}/cpu/x86/pc/tsccal1.fth -[then]
0 0 hex mem-uart-base (u.) " /" begin-package 4 encode-int 0 encode-int encode+ " interrupts" property
Modified: cpu/x86/pc/alex/fw.bth ============================================================================== --- cpu/x86/pc/alex/fw.bth Tue Aug 9 20:32:13 2011 (r2450) +++ cpu/x86/pc/alex/fw.bth Tue Aug 9 20:33:10 2011 (r2451) @@ -177,9 +177,6 @@ fload ${BP}/ofw/inet/http.fth \ HTTP client end-support-package
-[ifndef] use-timestamp-counter -fload ${BP}/cpu/x86/pc/mscal.fth -[then] fload ${BP}/cpu/x86/pc/boot.fth fload ${BP}/cpu/x86/pc/linux.fth
