Author: wmb Date: Thu Jan 20 00:28:37 2011 New Revision: 2126 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2126
Log: Mostly-cosmetic changes to the wrapper. You can turn on simulator sign-on chattiness by defining VERBOSE.
Modified: forth/wrapper/wrapper.c
Modified: forth/wrapper/wrapper.c ============================================================================== --- forth/wrapper/wrapper.c Thu Jan 20 00:26:40 2011 (r2125) +++ forth/wrapper/wrapper.c Thu Jan 20 00:28:37 2011 (r2126) @@ -347,11 +347,11 @@ INTERNAL long f_crstr();
#if defined(PPCSIM) || defined (ARMSIM) - /* These are not INTERNAL because the PowerPC simulator uses then */ - long c_key(); - long s_bye(); - void simulate(); - void restoremode(); + /* These are not INTERNAL because the simulators use then */ + long c_key(); + long s_bye(); + void simulate(); + void restoremode(); #else INTERNAL long c_key(); INTERNAL long s_bye(); @@ -1002,9 +1002,15 @@ dictsize = sizeof(header) + imagesize + extrasize ; dictsize += 16; /* Allow for alignment */
-# ifdef PPCSIM +# ifdef VERBOSE +# ifdef PPCSIM printf("PowerPC Instruction Set Simulator\n"); printf("Copyright 1994 FirmWorks All rights reserved\n"); +# elif ARMSIM + printf("ARM Instruction Set Simulator\n"); + printf("Copyright 1994 FirmWorks All rights reserved\n"); + printf("Copyright 2010 Apple, Inc. All rights reserved\n"); +# endif # endif
loadaddr = (char *)m_alloc(dictsize); @@ -1063,7 +1069,6 @@ loadaddr, functions, ((long)loadaddr+dictsize - 16) & ~15, argc, argv, 1 /* 0=POWER, 1=PowerPC */); #elif defined(ARMSIM) - // printf("loadaddr = 0x%x\n",loadaddr); simulate(0L, loadaddr, loadaddr, functions, ((long)loadaddr+dictsize - 16) & ~15, argc, argv); #else
