Author: wmb Date: Tue Aug 3 21:43:50 2010 New Revision: 1904 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1904
Log: Checked-in auxiliary code to draw waveforms on "Tektronix vector displays" (as emulated by TeraTERM and xterm).
Added: cpu/x86/pc/olpc/via/tekwaveform.fth
Added: cpu/x86/pc/olpc/via/tekwaveform.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/x86/pc/olpc/via/tekwaveform.fth Tue Aug 3 21:43:50 2010 (r1904) @@ -0,0 +1,137 @@ +\ TeraTERM must be in AutoSwitch mode - Setup>Terminal - for to-tek and to-vt +\ to work. Otherwise you have to invoke the Tek emulator manually (Control>Open TEK) +\ and switch back and forth with the mouse +: to-tek ( -- ) h# 1f emit ; +: to-vt ( -- ) h# 1b emit [char] 2 emit ; + +: tek-page ( -- ) h# 1b emit h# c emit ; \ Clear screen + +: tek-alpha ( -- ) h# 1f emit ; +: tek-plot ( -- ) h# 1d emit ; + +: component ( n tag -- ) swap h# 1f and or emit ; + +d# 1024 constant screen-width +d# 780 constant screen-height + +: tek-move ( x y -- ) + \ Clip the xy components so they can be represented in the + \ 10 bit width of the encoding protocol. + d# 1023 min ( x y' ) + dup 5 rshift h# 20 component ( x y ) \ hi-y + h# 60 component ( x ) \ lo-y + d# 1023 min ( x' ) + dup 5 rshift h# 20 component ( x ) \ hi-x + h# 40 component ( ) \ lo-x +; +\ Here's how line drawing works. Starting in alphanumeric mode: +\ Execute tek-plot to get into line drawing mode. The pen is +\ now up, so the first line is invisible, i.e. it's a move. +\ The pen automatically goes down after the first move, and +\ subsequent moves draw lines. tek-alpha gets you out of +\ drawing mode. + +: tek-box ( -- ) + to-tek + tek-plot + 10 10 tek-move \ initial non-drawn move + 40 10 tek-move + 40 60 tek-move + 10 60 tek-move + 10 10 tek-move + tek-alpha + to-vt +; + +\ PostScript-style line drawing commands + +variable cur-x variable cur-y +: moveto ( x y -- ) cur-y ! cur-x ! ; +: tek-at ( x y -- ) + moveto tek-plot cur-x @ cur-y @ tek-move tek-alpha +; +: lineto ( x y -- ) +\ to-tek + tek-plot + cur-x @ cur-y @ tek-move ( x y ) + 2dup moveto tek-move ( ) + tek-alpha +\ to-vt +; +: rline ( dx dy -- ) swap cur-x @ + swap cur-y @ + lineto ; + +: box2 ( -- ) + tek-page + 10 10 moveto + 40 10 lineto + 40 60 lineto + 10 60 lineto + 10 10 lineto + to-vt +; + +alias clear-plot tek-page +0 constant white +1 constant black +2 constant red +3 constant green +4 constant blue +5 constant cyan +6 constant magenta +7 constant yellow +: set-fg ( n -- ) h# 1b emit ." ML" h# 30 + emit ; + +0 [if] +\ Incremental plotting mode; not very useful. Exit with tek-alpha +: tek-turtle ( -- ) h# 1e emit ; +: unpen ( -- ) bl emit ; +: pen ( -- ) [char] P emit ; +: east ( -- ) [char] A emit ; +: west ( -- ) [char] B emit ; +: north ( -- ) [char] D emit ; +: south ( -- ) [char] H emit ; +: nw ( -- ) [char] F emit ; +: ne ( -- ) [char] E emit ; +: sw ( -- ) [char] J emit ; +: se ( -- ) [char] I emit ; +[then] + +\ End of tek.fth + + +7 constant wave-scale +: wave-height 1 d# 15 wave-scale - << 2+ ; + +: wave0 ( -- ) screen-height wave-height - ; + +: plot0 ( -- x y ) 0 d# 10 ; + +variable ylim variable ymin +1 value stretch +: clip-y ( value -- value' ) ymin @ - 0 max ylim @ min ; +: plot ( xt xmin xmax xscale ymin ymax -- ) + over - ylim ! ymin ! to stretch ( xt xmin xmax ) + over 3 pick execute clip-y ( xt xmin xmax y-at-xmin ) + plot0 2 pick - moveto ( xt xmin xmax y-at-xmin ) + -rot swap 1+ ?do ( xt last ) + i 2 pick execute clip-y ( xt last value ) + tuck - ( xt value delta ) + stretch swap rline ( xt value ) + loop ( xt last ) + 2drop ( ) +; + +: clear-waveform ( -- ) clear-plot ; +: waveform-start ( -- ) 0 wave0 moveto ; +: draw-wave ( adr ) + 0 swap ( last adr ) + screen-width 0 do ( last adr ) + tuck <w@ ( adr last this-unscaled ) + wave-scale >>a ( adr last this ) + tuck swap - ( adr this distance ) + 1 swap rline ( adr this ) + swap wa1+ ( this adr ) + loop ( last adr ) + 2drop +; +: waveform ( adr -- ) clear-waveform waveform-start draw-wave to-vt ;
