Author: quozl Date: Wed Dec 5 09:02:09 2012 New Revision: 3471 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3471
Log: usbserial - FTDI232 driver for OLPC serial adapters
Modified: dev/usb2/device/serial/common.fth dev/usb2/device/serial/ftdi.fth dev/usb2/device/serial/uart.fth dev/usb2/device/serial/usbserial.bth dev/usb2/device/serial/vendor.fth
Modified: dev/usb2/device/serial/common.fth ============================================================================== --- dev/usb2/device/serial/common.fth Wed Dec 5 04:44:52 2012 (r3470) +++ dev/usb2/device/serial/common.fth Wed Dec 5 09:02:09 2012 (r3471) @@ -107,6 +107,29 @@ ; ' generic-rpoll to rpoll
+[ifndef] /string +: /string ( adr len cnt -- adr' len' ) tuck - -rot + swap ; +[then] + +: generic-read-bytes ( adr len -- #read ) \ -2 for none available right now + rpoll + dup 0= if nip exit then ( adr len ) + read-q deque? 0= if ( adr len ) + 2drop ( ) + lost-carrier? if -1 false to lost-carrier? else -2 then + ( -2:none | -1:down ) + exit + then ( adr len char ) + over >r ( adr len char r: len ) + begin ( adr len char r: len ) + 2 pick c! ( adr len r: len ) + 1 /string ( adr' len' ) + dup 0= if 2drop r> exit then ( adr' len' ) + read-q deque? 0= until ( adr len r: len ) + nip r> swap - ( actual ) +; +' generic-read-bytes to read-bytes + : generic-write-bytes ( adr len -- actual ) swap >r ( len ) ( R: adr ) /outbuf /mod ( rem #loop )
Modified: dev/usb2/device/serial/ftdi.fth ============================================================================== --- dev/usb2/device/serial/ftdi.fth Wed Dec 5 04:44:52 2012 (r3470) +++ dev/usb2/device/serial/ftdi.fth Wed Dec 5 09:02:09 2012 (r3471) @@ -20,10 +20,14 @@ : ftdi-flush-rx ( -- ) 0 1 ftdi-set ; : ftdi-flush-tx ( -- ) 0 2 ftdi-set ;
+[ifndef] rounded-/ +: rounded-/ swap 2* swap / dup 1 and + 2/ ; +[then] + : ftdi-baud ( baud -- ) \ There are some high bits for fractional divisors that we don't use d# 48000000 swap rounded-/ ( divisor ) - 0 swap 3 ftdi-set + 4 rshift 3 ftdi-set ;
: ftdi-modem-ctl ( code -- ) 1 ftdi-set ; @@ -69,4 +73,73 @@ \ If there is any real data, it will be returned in bytes 2, ... \ If there is no data, 2-byte status messages are sent every 40 ms.
+: ftdi-rpoll ( -- ) + bulk-in? if drop restart-bulk-in exit then \ USB error; restart + ?dup if + 2 ?do + inbuf i ca+ c@ read-q enque + loop + restart-bulk-in + then +; + \ Data is transmitted on bulk endpoint 2, verbatim. + +: ftdi-rts-dtr-off ( -- ) + ftdi-rts-off + ftdi-dtr-off +; + +: ftdi-rts-dtr-on ( -- ) + ftdi-rts-on + ftdi-dtr-on +; + +: ftdi-set-baud ( -- ) + d# 115200 ftdi-baud + ftdi-rts-dtr-on + ftdi-8n1 + ftdi-flow-none +; + +: ftdi-inituart ( -- ) + ftdi-set-baud +; + + +: init-ftdi ( -- ) + ['] ftdi-rts-dtr-off to rts-dtr-off + ['] ftdi-rts-dtr-on to rts-dtr-on + ['] ftdi-rpoll to rpoll + ['] ftdi-inituart to inituart +; + +: init ( -- ) + init + vid pid uart-ftdi? if init-ftdi then +; + + +\ LICENSE_BEGIN +\ Copyright (c) 2012 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: dev/usb2/device/serial/uart.fth ============================================================================== --- dev/usb2/device/serial/uart.fth Wed Dec 5 04:44:52 2012 (r3470) +++ dev/usb2/device/serial/uart.fth Wed Dec 5 09:02:09 2012 (r3471) @@ -11,8 +11,6 @@
variable refcount 0 refcount !
-: /string ( adr len cnt -- adr' len' ) tuck - -rot + swap ; - \ Don't do this until someone calls read. That makes the device \ work as a console, with separate input and output instances 0 value read-started? @@ -32,21 +30,7 @@ \ no more characters are immediately available. : read ( adr len -- #read ) \ -2 for none available right now ?start-reading - rpoll - dup 0= if nip exit then ( adr len ) - read-q deque? 0= if ( adr len ) - 2drop ( ) - lost-carrier? if -1 false to lost-carrier? else -2 then - ( -2:none | -1:down ) - exit - then ( adr len char ) - over >r ( adr len char r: len ) - begin ( adr len char r: len ) - 2 pick c! ( adr len r: len ) - 1 /string ( adr' len' ) - dup 0= if 2drop r> exit then ( adr' len' ) - read-q deque? 0= until ( adr len r: len ) - nip r> swap - ( actual ) + read-bytes ;
: write ( adr len -- actual ) dup if write-bytes else nip then ;
Modified: dev/usb2/device/serial/usbserial.bth ============================================================================== --- dev/usb2/device/serial/usbserial.bth Wed Dec 5 04:44:52 2012 (r3470) +++ dev/usb2/device/serial/usbserial.bth Wed Dec 5 09:02:09 2012 (r3471) @@ -16,6 +16,7 @@ fload ${BP}/dev/usb2/device/serial/belkin.fth \ Belkin device routines fload ${BP}/dev/usb2/device/serial/mct_u232.fth \ MCT U232 device routines fload ${BP}/dev/usb2/device/serial/pl2303.fth \ PL2303 device routines +fload ${BP}/dev/usb2/device/serial/ftdi.fth \ FTDI device routines fload ${BP}/dev/usb2/device/serial/uart.fth \ USB uart driver
end0
Modified: dev/usb2/device/serial/vendor.fth ============================================================================== --- dev/usb2/device/serial/vendor.fth Wed Dec 5 04:44:52 2012 (r3470) +++ dev/usb2/device/serial/vendor.fth Wed Dec 5 09:02:09 2012 (r3471) @@ -7,6 +7,10 @@ 525 w, 127a w, \ Ajays USB 2.0 Debug Cable here swap - constant /uart-generic-list
+create uart-ftdi-list here + 403 w, 6001 w, \ FT232 +here swap - constant /uart-ftdi-list + create uart-pl2303-list here 557 w, 2008 w, \ ATEN, IOGear 67b w, 2303 w, \ PL2303 @@ -33,6 +37,9 @@ uart-generic-list /uart-generic-list find-vendor-product? ;
+: uart-ftdi? ( vid pid -- flag ) + uart-ftdi-list /uart-ftdi-list find-vendor-product? +;
: uart-pl2303? ( vid pid -- flag ) uart-pl2303-list /uart-pl2303-list find-vendor-product? @@ -47,7 +54,8 @@ ;
: usb-uart? ( vid pid -- flag ) - 2dup uart-pl2303? if 2drop true exit then + 2dup uart-ftdi? if 2drop true exit then + 2dup uart-pl2303? if 2drop true exit then \ Not debugged yet... \ 2dup uart-mct? if 2drop true exit then 2dup uart-belkin? if 2drop true exit then
