Author: wmb Date: Tue Nov 29 01:26:31 2011 New Revision: 2708 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2708
Log: Initial revision of Newton files
Added: cpu/x86/pc/newton/devices.fth
Added: cpu/x86/pc/newton/devices.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/x86/pc/newton/devices.fth Tue Nov 29 01:26:31 2011 (r2708) @@ -0,0 +1,237 @@ +\ See license at end of file +purpose: Load device drivers according to configuration definitions + +0 0 " " " /" begin-package + fload ${BP}/cpu/x86/pc/mappci.fth \ Map PCI to root + fload ${BP}/dev/pcibus.fth \ Generic PCI bus package + + 0 0 " addresses-preassigned" property +[then] + + fload ${BP}/cpu/x86/pc/newton/pcinode.fth \ System-specific words for PCI +end-package +stand-init: PCI host bridge + " /pci" " init" execute-device-method drop +; + +fload ${BP}/dev/pciprobe.fth \ Generic PCI probing + +\ Use the CPU chip's Time Stamp Counter for timing +fload ${BP}/cpu/x86/tsc.fth + +0 0 " " " /" begin-package + fload ${BP}/cpu/x86/pc/isabus.fth \ ISA Bus Bridge under root node +end-package + +dev /interrupt-controller +h# 20 to vector-base0 +h# 28 to vector-base1 +device-end + +fload ${BP}/dev/olpc/spiflash/flashif.fth \ Generic FLASH interface + +fload ${BP}/dev/olpc/spiflash/memflash.fth \ Memory-mapped FLASH read access + +warning @ warning off +: stand-init-io stand-init-io h# fff8.0000 to flash-base ; +warning ! + +fload ${BP}/ofw/fs/cbfs.fth \ Coreboot ROM filesystem + +\ Create the top-level device node to access the entire boot FLASH device +0 0 " ffa00000" " /" begin-package + " flash" device-name + + h# 10.0000 value /device + h# 10.0000 constant /device-phys + my-address my-space /device-phys reg + fload ${BP}/dev/flashpkg.fth + fload ${BP}/dev/flashwrite.fth +end-package + +\ XXX later +\ devalias cbfs /flash//cbfs-file-system + +0 [if] +\ This really should be a subrange of /flash +0 0 dropin-base <# u#s u#> " /" begin-package + " dropinram" device-name + + dropin-size + dup value /device + constant /device-phys + my-address my-space /device-phys reg + fload ${BP}/dev/flashpkg.fth +end-package + +devalias dropins /dropinram +[else] +patch /l /di-header first-header +patch /l /di-header first-header +\ devalias dropins cbfs:fallback\payload +devalias dropins /flash +[then] + +\ Create a pseudo-device that presents the dropin modules as a filesystem. +fload ${BP}/ofw/fs/dropinfs.fth + +\ This devalias lets us say, for example, "dir rom:" +devalias rom /dropin-fs + +fload ${BP}/cpu/x86/forthint.fth \ Low-level interrupt handling code +fload ${BP}/dev/isa/irq.fth \ ISA interrupt dispatcher +fload ${BP}/cpu/x86/pc/isatick.fth \ Use ISA timer as the alarm tick timer +fload ${BP}/cpu/x86/pc/olpc/timertest.fth \ Selftest for PIT timer + +fload ${BP}/dev/pci/isaall.fth +devalias mouse /usb/mouse + +fload ${BP}/cpu/x86/pc/tsccal1.fth + +fload ${BP}/dev/null2.fth + +[ifdef] serial-console +[ifdef] resident-packages +support-package: 16550 +fload ${BP}/dev/16550pkg/16550.fth \ Serial port support package +end-support-package +[then] + +0 0 hex mem-uart-base (u.) " /" begin-package + 4 encode-int 0 encode-int encode+ " interrupts" property + fload ${BP}/dev/16550pkg/ns16550p.fth + d# 64,000,000 " clock-frequency" integer-property + fload ${BP}/dev/16550pkg/isa-int.fth +end-package +devalias com1 /serial:115200 +: com1 ( -- adr len ) " com1" ; +' com1 to fallback-device +[else] +: devnull ( -- adr len ) " /null" ; +' devnull to fallback-device +[then] + +0 0 " i70" " /isa" begin-package \ Real-time clock node + fload ${BP}/dev/ds1385r.fth + 8 encode-int 0 encode-int encode+ " interrupts" property + 2 encode-int " device#" property +end-package +stand-init: RTC + " /rtc" open-dev clock-node ! +; + +fload ${BP}/cpu/x86/pc/cpunode.fth +fload ${BP}/cpu/x86/k6cputest.fth \ Burnin test for K6 CPU +dev /cpu 1 to default#passes dend + +fload ${BP}/ofw/core/countdwn.fth \ Startup countdown +fload ${BP}/forth/lib/pattern.fth \ Text string pattern matching +fload ${BP}/forth/lib/tofile.fth \ to-file and append-to-file +\ XXX remove the OS file commands from tools.dic +fload ${BP}/ofw/core/filecmds.fth \ File commands: dir, del, ren, etc. + +[ifdef] use-ega +0 0 " " " /" begin-package + fload ${BP}/dev/egatext.fth +end-package +devalias screen /ega-text +[then] + +[ifdef] use-vesa +fload ${BP}/dev/video/controlr/vesa.fth +devalias screen /display \ Explicit, because it's not probed +[then] + +[ifdef] use-pineview +0 0 " 2,0" " /pci" begin-package + " display" name + fload ${BP}/dev/intel/graphics/pineview.fth + alias /scanline bytes/line + fload ${BP}/dev/video/common/rectangle16.fth + alias color! 4drop +end-package +devalias screen /pci/display@2,0 \ Explicit, because it's not probed +[then] + +\ Create the alias unless it already exists +: $?devalias ( alias$ value$ -- ) + 2over not-alias? if $devalias exit then ( alias$ value$ alias$ ) + 2drop 4drop +; + +: report-disk ( -- ) + " /pci-ide" locate-device 0= if + drop + " disk" " /pci-ide/ide@0/disk@0" $devalias + " c" " /pci-ide/ide@0/disk@0" $devalias + " d" " /pci-ide/ide@0/disk@1" $devalias + " e" " /pci-ide/ide@1/disk@0" $devalias + " f" " /pci-ide/ide@1/disk@1" $devalias + exit + then + " /ide" locate-device 0= if + drop + " disk" " /ide@1f0/disk@0" $devalias + " c" " /ide@1f0/disk@0" $devalias + " d" " /ide@170/disk@1" $devalias + " e" " /ide@1f0/disk@0" $devalias + " f" " /ide@170/disk@2" $devalias + exit + then +; + +fload ${BP}/cpu/x86/inoutstr.fth \ Multiple I/O port read/write + +[ifdef] serial-console +fload ${BP}/dev/isa/diaguart.fth \ ISA COM port driver +fload ${BP}/forth/lib/sysuart.fth \ Use UART for key and emit +[else] +fload ${BP}/dev/nulluart.fth \ Null UART driver +[then] +[ifdef] use-ega +fload ${BP}/cpu/x86/pc/egauart.fth \ Output also to EGA +[then] + +0 value keyboard-ih +0 value screen-ih + +fload ${BP}/ofw/core/muxdev.fth \ I/O collection/distribution device + +fload ${BP}/dev/olpc/spiflash/spiif.fth \ Generic low-level SPI bus access +fload ${BP}/dev/intel/spi.fth \ SPI FLASH programming + +\ XXX we probably need to use the port CF9 method +fload ${BP}/cpu/x86/pc/reset.fth \ reset-all + +\ fload ${BP}/dev/acpiec.fth \ Access to ACPI EC internal variables +\ fload ${BP}/cpu/x86/pc/newton/ec.fth \ Battery, AC, CPU temperature, Fan controls + +: ?enough-power ; \ Implement based on AC presence and battery status + +fload ${BP}/cpu/x86/pc/newton/spiui.fth \ User interface for SPI FLASH programming +: urom ( -- ) " flash! u:\stumpy.rom" evaluate ; +: netrom ( -- ) " flash! http:\192.168.200.200\stumpy.rom" evaluate ; + +\ LICENSE_BEGIN +\ Copyright (c) 2011 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
