Author: wmb Date: 2009-12-15 01:10:05 +0100 (Tue, 15 Dec 2009) New Revision: 1605
Modified: dev/usb2/device/keyboard/kbd.fth Log: USB keyboard - clarified error messages and suppressed the "Failed to set idle" message since it is not critical.
Modified: dev/usb2/device/keyboard/kbd.fth =================================================================== --- dev/usb2/device/keyboard/kbd.fth 2009-12-15 00:01:16 UTC (rev 1604) +++ dev/usb2/device/keyboard/kbd.fth 2009-12-15 00:10:05 UTC (rev 1605) @@ -379,9 +379,11 @@ null-entry /qe erase key-state /key-state erase device set-target - configuration set-config if ." Failed to set keyboard configuration" cr then - set-boot-protocol if ." Failed to set boot protocol" cr then - idle-rate set-idle if ." Failed to set idle" cr then + configuration set-config if ." Failed to set USB keyboard configuration" cr then + set-boot-protocol if ." Failed to set USB keyboard boot protocol" cr then + \ Some USB keyboards don't implement set-idle properly, and it's not critical, + \ so we suppress the message to avoid confusing the user + idle-rate set-idle drop \ if ." Failed to set USB keyboard idle" cr then 0 set-leds free-kbd-buf ;
