Author: wmb Date: Mon Mar 25 23:53:09 2013 New Revision: 3625 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3625
Log: Audio selftest - trivial refactoring to make interactive testing easier.
Modified: dev/geode/ac97/selftest.fth
Modified: dev/geode/ac97/selftest.fth ============================================================================== --- dev/geode/ac97/selftest.fth Mon Mar 25 23:50:45 2013 (r3624) +++ dev/geode/ac97/selftest.fth Mon Mar 25 23:53:09 2013 (r3625) @@ -148,14 +148,20 @@ d# -3 set-volume play ;
+: alloc-test-buf ( -- ) + record-len la1+ " dma-alloc" $call-parent to record-base +; +: free-test-buf ( -- ) + record-base record-len la1+ " dma-free" $call-parent +; 0 value skip-sweep? : selftest ( -- error? ) open 0= if ." Failed to open /audio" cr true exit then wav-test - record-len la1+ " dma-alloc" $call-parent to record-base + alloc-test-buf skip-sweep? 0= if sweep-test then mic-test - record-base record-len la1+ " dma-free" $call-parent + free-test-buf close false ;
