Author: wmb Date: Tue Aug 28 18:25:18 2012 New Revision: 3232 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3232
Log: OLPC ARM - MMP audio driver - Some tweaking of device tree properties for the benefit of the Linux driver.
Modified: cpu/arm/olpc/sound.fth
Modified: cpu/arm/olpc/sound.fth ============================================================================== --- cpu/arm/olpc/sound.fth Tue Aug 28 10:03:02 2012 (r3231) +++ cpu/arm/olpc/sound.fth Tue Aug 28 18:25:18 2012 (r3232) @@ -10,18 +10,36 @@ [ifdef] mmp3 h# c0ffd000 [else] h# d42a0000 [then] + ;
+\ "mav" stands for M(DMA), A(DMA), V(DMA), distinct from +\ the 16 "peripheral" PDMA channels. +\ The number space for mmp-mav-dma-channels is as follows: +\ 0: MDMA0 +\ 1: MDMA1 +\ 2: ADMA1_CH0 (out) +\ 3: ADMA1_CH1 (in) +\ 4: ADMA2_CH0 (out) +\ 5: ADMA2_CH1 (in) +\ 6: VDMA1_CH0 +\ 7: VDMA1_CH1 +\ That's consistent with the enumeration mmp_tdma_type in +\ Linux:arch/arm/mach-mmp/include/mach/mmp_dma.h +\ and also reflects the bit numbering (+16) in the various +\ DMA IRQ status and mask registers, e.g. ICU_DMA_IRQ1_STATUS + dev / new-device " adma" device-name h# 800 +audio h# 100 reg - d# 47 " interrupts" integer-property + 3 encode-int 2 encode-int encode+ " mmp-mav-dma-channels" property + " marvell,mmp-audio-dma" +compatible current-device ( adma0-ph ) finish-device
new-device " adma" device-name h# 900 +audio h# 100 reg - d# 48 " interrupts" integer-property + 5 encode-int 4 encode-int encode+ " mmp-mav-dma-channels" property + " marvell,mmp-audio-dma" +compatible current-device ( adma0-ph adma1-ph ) finish-device
@@ -31,7 +49,7 @@
\ We call this the platform driver, a single point that collects \ the Audio DMA resources - " mrvl,mmp-pcm-audio" +compatible \ snd_soc_dai_link.cpu_dai_of_node + " marvell,mmp-pcm-audio" +compatible \ snd_soc_dai_link.cpu_dai_of_node
( adma0-ph adma1-ph ) encode-int rot encode-int encode+ " adma-nodes" property @@ -41,7 +59,7 @@ " sspa" name h# d00 +audio h# 100 reg
- " mrvl,mmp-sspa-dai" +compatible + " marvell,mmp-sspa-dai" +compatible
" /pmua" encode-phandle d# 20 encode-int encode+ " clocks" property d# 3 " interrupts" integer-property @@ -52,7 +70,7 @@ " audio" name h# c00 +audio h# 100 reg
-" mrvl,mmp-sspa-dai" +compatible +" marvell,mmp-sspa-dai" +compatible
" /pmua" encode-phandle d# 20 encode-int encode+ " clocks" property d# 2 " interrupts" integer-property
