Author: quozl Date: Wed Jun 8 02:39:34 2011 New Revision: 2255 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2255
Log: OLPC XO-1.5 trac #10970 - avoid disabling the F segment since it is in use by the DSDT at the time.
Modified: cpu/x86/pc/olpc/via/dsdt-c2only.dsl cpu/x86/pc/olpc/via/dsdt.dsl
Modified: cpu/x86/pc/olpc/via/dsdt-c2only.dsl ============================================================================== --- cpu/x86/pc/olpc/via/dsdt-c2only.dsl Wed Jun 8 02:19:29 2011 (r2254) +++ cpu/x86/pc/olpc/via/dsdt-c2only.dsl Wed Jun 8 02:39:34 2011 (r2255) @@ -331,7 +331,7 @@
IF (LEqual(Arg0, 0x03)) //S3 { - Store(0x2,_SB.PCI0.MEMC.FSEG) //Set F Segment to Read only + // Store(0x2,_SB.PCI0.MEMC.FSEG) //Set F Segment to Read only // Notify(_SB.PCI0, 0x00) }
@@ -373,7 +373,7 @@ } //End of Arg0 EQ 0x01
IF (LEqual(Arg0, 0x03)) { // S3 - Store(0x0,_SB.PCI0.MEMC.FSEG) // Disable F Segment Read/Write + // Store(0x0,_SB.PCI0.MEMC.FSEG) // Disable F Segment Read/Write }
IF (LEqual(Arg0, 0x04)) { //S4
Modified: cpu/x86/pc/olpc/via/dsdt.dsl ============================================================================== --- cpu/x86/pc/olpc/via/dsdt.dsl Wed Jun 8 02:19:29 2011 (r2254) +++ cpu/x86/pc/olpc/via/dsdt.dsl Wed Jun 8 02:39:34 2011 (r2255) @@ -333,7 +333,7 @@
@@ -375,7 +375,7 @@ } //End of Arg0 EQ 0x01
