Author: wmb Date: 2010-01-07 22:12:26 +0100 (Thu, 07 Jan 2010) New Revision: 1648
Modified: ofw/fs/ext2fs/methods.fth Log: OLPC trac 9957 - prevent duplicate names when using $rename or hardlink on ext2 file systems.
Modified: ofw/fs/ext2fs/methods.fth =================================================================== --- ofw/fs/ext2fs/methods.fth 2010-01-07 08:04:00 UTC (rev 1647) +++ ofw/fs/ext2fs/methods.fth 2010-01-07 21:12:26 UTC (rev 1648) @@ -39,11 +39,16 @@ : $delete! $delete ; \ XXX should these be different?
: $hardlink ( old-name$ new-name$ -- error? ) + \ Error if the new name already exists + 2dup $find-file 0= if ( old-name$ new-name$ ) + 4drop true exit ( -- true ) + then ( old-name$ new-name$ ) + \ Save the current search context. The path part of the new name \ has already been parsed out and resolved. Resolving old-name$ changes \ the directory context, so we will need to restore the context for the \ new name to create its dirent. - dirent-vars 2>r 2>r ( new-name$ r: 4xVars ) + dirent-vars 2>r 2>r ( old-name$ new-name$ r: 4xVars )
2swap $find-file if ( new-name$ r: 4xVars ) 2drop 2r> 2r> 4drop true exit @@ -51,7 +56,7 @@
\ Hard links to directories mess up the filesystem tree wf-type dir-type = if 2drop true exit then ( new-name$ r: 4xVars) - + 2r> 2r> restore-dirent ( new-name$ ) wf-inum new-dirent ( error? ) ; @@ -105,7 +110,7 @@ dirent-unlink ( r: dir-i# )
r> drop ( ) - + false ;
@@ -134,7 +139,7 @@ ;
: ext2fsfread ( addr count 'fh -- #read ) - drop + drop dup bsize > abort" Bad size for ext2fsfread" file-size lblk# bsize * - ( addr count rem ) umin swap ( actual addr ) @@ -143,7 +148,7 @@ ;
: ext2fsfwrite ( addr count 'fh -- #written ) - drop + drop dup bsize > abort" Bad size for ext2fsfwrite" ( addr count ) tuck lblk# bsize * + dup file-size u> if ( actual addr new ) file-size! \ changing byte count, NOT #blks @@ -151,7 +156,7 @@ drop then ( actual addr ) lblk# write-file-block ( actual ) - + \ XXX I am skeptical about this line. dup 0> if lblk#++ then ( actual ) true to modified? @@ -164,7 +169,7 @@
dirent-inode@ set-inode ( mode ) false to modified? - + >r bsize alloc-mem bsize initbuf dirent-inode@ r@ ['] ext2fsdflen ['] ext2fsdfalign ['] ext2fsfclose ['] ext2fsdfseek
