Author: wmb Date: Fri Mar 16 02:02:28 2012 New Revision: 2894 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2894
Log: ARM MMP2 timer driver - improved the code that reads the timer values. The technique I was using to ensure a self-consistent read was bogus, and the hardware documentation is extremely unclear. It turns out that you need to use different techniques for the different timers - careful write/read synchronization for the fast one, and read-until-match for the slower ones.
Modified: cpu/arm/mmp2/timer.fth
Modified: cpu/arm/mmp2/timer.fth ============================================================================== --- cpu/arm/mmp2/timer.fth Thu Mar 15 00:19:06 2012 (r2893) +++ cpu/arm/mmp2/timer.fth Fri Mar 16 02:02:28 2012 (r2894) @@ -21,37 +21,46 @@ 7 h# 84 timer! ;
-[ifdef] arm-assembler +\ The first ldr usually returns stale data; the second one returns good data. +\ Empirically, draining the write buffer does not help. +\ Read-until-match doesn't work with the fast clock because it never matches. code timer0@ ( -- n ) \ 6.5 MHz psh tos,sp set r1,`h# 014000 +io #` mov r0,#1 str r0,[r1,#0xa4] - mov r0,r0 - ldr tos,[r1,#0x28] + ldr tos,[r1,#0xa4] + ldr tos,[r1,#0xa4] c;
+\ For the slower timers, we use the read-until-match technique. +\ Apparently the freeze register doesn't update until the next +\ clock tick, so using it doesn't work well for the slow clocks. code timer1@ ( -- n ) \ 32.768 kHz psh tos,sp set r1,`h# 014000 +io #` - mov r0,#1 - str r0,[r1,#0xa8] - mov r0,r0 ldr tos,[r1,#0x2c] + begin + mov r0,tos + ldr tos,[r1,#0x2c] + cmps tos,r0 + = until c;
code timer2@ ( -- n ) \ 1 kHz psh tos,sp set r1,`h# 014000 +io #` - mov r0,#1 - str r0,[r1,#0xac] - mov r0,r0 ldr tos,[r1,#0x30] + begin + mov r0,tos + ldr tos,[r1,#0x30] + cmps tos,r0 + = until c; [else] -: timer0@ ( -- n ) 1 h# 0140a4 io! h# 014028 io@ ; -: timer1@ ( -- n ) 1 h# 0140a8 io! h# 01402c io@ ; -: timer2@ ( -- n ) 1 h# 0140ac io! h# 014030 io@ ; +: timer0@ ( -- n ) 1 h# 0140a4 io! h# 0140a4 io@ drop h# 0140a4 io@ ; +: timer1@ ( -- n ) 1 h# 0140a8 io! h# 0140a8 io@ drop h# 0140a8 io@ ; +: timer2@ ( -- n ) 1 h# 0140ac io! h# 0140ac io@ drop h# 0140ac io@ ; [then]
: timer0-status@ ( -- n ) h# 014034 io@ ;
