Author: quozl Date: Mon Mar 19 22:52:46 2012 New Revision: 2900 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2900
Log: OLPC - add fs-resize, no change to fs-update, fs-resize enlarges the second partition to fill remaining space on eMMC or microSD, may be followed up with manual use of "resize2fs /dev/mmcblk0p2", does not require initramfs or olpc-os-builder support. #11690
Modified: cpu/x86/pc/olpc/via/fsupdate.fth
Modified: cpu/x86/pc/olpc/via/fsupdate.fth ============================================================================== --- cpu/x86/pc/olpc/via/fsupdate.fth Mon Mar 19 21:05:21 2012 (r2899) +++ cpu/x86/pc/olpc/via/fsupdate.fth Mon Mar 19 22:52:46 2012 (r2900) @@ -93,6 +93,41 @@ fexit ;
+h# 1be. 2value pt \ device byte offset to start of partition table +h# 10 value /pe \ size of a partition entry +/pe buffer: pe \ partition entry buffer + +: pe-seek ( partition# -- ) + 1- /pe * 0 pt d+ ( d.pos ) + " seek" nandih $call-method drop ( ) +; + +: pe-read ( partition# -- ) pe-seek pe /pe " read" nandih $call-method drop ; +: pe-write ( partition# -- ) pe-seek pe /pe " write" nandih $call-method drop ; + +: pe-start@ ( pe -- start ) pe h# 08 + le-l@ ; +: pe-length@ ( pe -- length ) pe h# 0c + le-l@ ; +: pe-length! ( length pe -- ) pe h# 0c + le-l! ; + +: pe-is-set? ( partition# -- flag ) pe-read pe-start@ pe-length@ or ; + +: (resize:) ( -- ) + 4 pe-is-set? abort" partition 4 is non-zero" + 3 pe-is-set? abort" partition 3 is non-zero" + " size" nandih $call-method d# 512 um/mod swap drop + ( d-end ) + 2 pe-read ( d-end ) + pe-start@ dup >r ( d-end p-start ) ( r: p-start ) + pe-length@ + swap ( p-end d-end ) ( r: p-start ) + 2dup > abort" partition ends beyond device size" + 2dup < if ( p-end d-end ) ( r: p-start ) + nip r> - pe-length! ( ) ( r: ) + 2 pe-write ( ) ( r: ) + else ( p-end d-end ) ( r: p-start ) + r> 3drop ( ) ( r: ) + then ( ) ( r: ) +; + : data: ( "filename" -- ) safe-parse-word ( filename$ ) nb-zd-#sectors -1 <> if ( filename$ ) @@ -243,6 +278,12 @@ safe-parse-word $fs-update ;
+: fs-resize ( -- ) + open-nand + [ also nand-commands ] (resize:) [ previous ] + close-nand +; + : do-fs-update ( img$ -- ) tuck load-base h# c00000 + swap move ( len ) load-base h# c00000 + swap ( adr len )
