Author: wmb Date: 2009-10-07 20:56:31 +0200 (Wed, 07 Oct 2009) New Revision: 1401
Modified: cpu/x86/pc/olpc/via/devices.fth cpu/x86/pc/olpc/via/usb.fth Log: OLPC trac 9480 - fixed net devalias - was /usb/wlan, now /wlan for SD-connected wlan module on XO-1.5
Modified: cpu/x86/pc/olpc/via/devices.fth =================================================================== --- cpu/x86/pc/olpc/via/devices.fth 2009-10-07 08:52:49 UTC (rev 1400) +++ cpu/x86/pc/olpc/via/devices.fth 2009-10-07 18:56:31 UTC (rev 1401) @@ -337,6 +337,7 @@ devalias ide /ide@0/disk devalias sd /sd/disk@2 devalias ext /sd/disk@2 +devalias net /wlan
\ The "int" devalias is defined in report-disk at runtime, since it \ varies between A-test and later boards. @@ -376,7 +377,7 @@
\ If there is a USB ethernet adapter, use it as the default net device. \ We can't use ?report-device here because we already have net aliased -\ to /usb/wlan, and ?report-device won't override an existing alias. +\ to /wlan, and ?report-device won't override an existing alias. : report-net ( -- ) " /usb/ethernet" 2dup locate-device 0= if ( name$ phandle ) drop ( name$ )
Modified: cpu/x86/pc/olpc/via/usb.fth =================================================================== --- cpu/x86/pc/olpc/via/usb.fth 2009-10-07 08:52:49 UTC (rev 1400) +++ cpu/x86/pc/olpc/via/usb.fth 2009-10-07 18:56:31 UTC (rev 1401) @@ -41,7 +41,6 @@ pwd$ $nopage-show-devs then ; -devalias net /usb/wlan
: probe-usb ( -- ) ." USB2 devices:" cr
