Author: quozl Date: Wed Sep 19 04:58:34 2012 New Revision: 3314 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3314
Log: OLPC XO-4 - Neonode, do not timeout test /touchscreen, #12113, add averaged response curve data collection.
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Tue Sep 18 05:27:06 2012 (r3313) +++ cpu/arm/olpc/nn-touchscreen.fth Wed Sep 19 04:58:34 2012 (r3314) @@ -467,6 +467,55 @@ 41 0 do ." y " i .d 1 i test-fss-axis-all loop ;
+[then] + + + +0 [if] \ fixed signal strength test, averaged, all power levels + +d# 100 value n \ number of tests to average + +xleds yleds max 2* constant /sums +create sums +/sums 4 * allot +: 0sums sums /sums 4 * erase ; + +: rc-signal ( n -- ) + dup /sums > abort" sum index too large" + pbuf 5 + over + c@ ( n signal ) + swap 4 * sums + ( signal address ) + dup @ ( signal address sum ) + rot + swap ! ( ) +; + +: rc-sample ( axis power -- ) + swap h# 0f h# 03 h# ee 5 bytes-out + h# 0f d# 20 anticipate + pbuf 2+ c@ h# 0f = if + pbuf 4 + c@ 0 do ( ) + i rc-signal + loop + then +; + +: rc-axis ( axis power -- ) + 0sums ( axis power ) + n 0 do 2dup rc-sample loop ( axis power ) + 2drop ( ) + pbuf 4 + c@ 0 do i 4 * sums + @ n / .d loop cr ( ) +; + +: rc + 41 0 do ." x " i .d 0 i rc-axis loop + 41 0 do ." y " i .d 1 i rc-axis loop +; + +[then] + + + +0 [if] \ fixed signal strength test, all power levels, as a response curve + : >scaled ( x y -- x' y' ) d# 3750 * d# 1000 / d# 900 swap - swap d# 1850 * d# 100 / swap @@ -743,10 +792,11 @@ defer (ev) ( x y -- ) \ touch event handler for tests ' noop to (ev) 0 value remaining +d# 30000 value test-timeout
: ev ( handler -- ) to (ev) - get-msecs d# 30000 + ( to ) + get-msecs test-timeout + ( to ) begin in? if pbuf 2+ c@ h# 04 = if \ touch notification event @@ -964,6 +1014,7 @@ faults if close true exit then then
+ test-station 6 = if d# 86400.000 to test-timeout then scribble
close false
