Author: wmb Date: Fri Dec 2 02:05:23 2011 New Revision: 2722 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2722
Log: biosload - replaced config.fth with a null version that tells you to select a specific configuration.
Modified: cpu/x86/pc/biosload/config.fth
Modified: cpu/x86/pc/biosload/config.fth ============================================================================== --- cpu/x86/pc/biosload/config.fth Fri Dec 2 02:05:17 2011 (r2721) +++ cpu/x86/pc/biosload/config.fth Fri Dec 2 02:05:23 2011 (r2722) @@ -1,48 +1,2 @@ -\ See license at end of file -purpose: Establish configuration definitions - -\ --- The environment that "boots" OFW --- -\ - Image Format - Example Media - previous stage bootloader - -create debug-startup -\ create serial-console -create resident-packages -create addresses-assigned \ Don't reassign PCI addresses -\ create virtual-mode -\ create use-root-isa -create use-timestamp-counter -create use-pci-isa -create use-isa-ide -create use-ega -create use-elf -\ create use-ne2000 -create use-watch-all -create pseudo-nvram -\ create use-null-nvram -\ create no-floppy-node - -fload ${BP}/cpu/x86/pc/biosload/addrs.fth - -\ LICENSE_BEGIN -\ Copyright (c) 2006 FirmWorks -\ -\ Permission is hereby granted, free of charge, to any person obtaining -\ a copy of this software and associated documentation files (the -\ "Software"), to deal in the Software without restriction, including -\ without limitation the rights to use, copy, modify, merge, publish, -\ distribute, sublicense, and/or sell copies of the Software, and to -\ permit persons to whom the Software is furnished to do so, subject to -\ the following conditions: -\ -\ The above copyright notice and this permission notice shall be -\ included in all copies or substantial portions of the Software. -\ -\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, -\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF -\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND -\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE -\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION -\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION -\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. -\ -\ LICENSE_END +.( !!! Copy a specific configuration file over config.fth !!!) cr +bye
