Author: wmb Date: 2008-12-04 10:17:43 +0100 (Thu, 04 Dec 2008) New Revision: 1013
Modified: dev/olpc/cafenand/cafenand.fth dev/olpc/cafenand/configure.fth dev/olpc/cafenand/lbanand.fth Log: OLPC NAND driver - speedup sequential writes by using the cached-write feature that some chips have.
Modified: dev/olpc/cafenand/cafenand.fth =================================================================== --- dev/olpc/cafenand/cafenand.fth 2008-12-04 09:17:39 UTC (rev 1012) +++ dev/olpc/cafenand/cafenand.fth 2008-12-04 09:17:43 UTC (rev 1013) @@ -37,6 +37,11 @@ h# 800 instance value /page h# 2.0000 instance value /eblock
+\ Chip capabilities +false instance value interleave? \ Chip-interleaved simultaneous programming +false instance value cached-write? \ Cached write support +1 instance value #simultaneous-writes \ Number of planes programmable at once + h# 40 constant /oob h# e constant /ecc h# e constant bb-offset \ Location of bad-block table signature in OOB data @@ -137,17 +142,20 @@ : dma-off ( -- ) 0 h# 40 cl! ;
0 value #writes -: wait-write-done ( -- error? ) +: (wait-write-done) ( -- status ) 0 ( status ) begin ( status ) drop ( ) read-status ( status ) dup h# 40 and ( status flag ) until ( status ) + #writes 1+ to #writes +; +: wait-write-done ( -- error? ) + (wait-write-done) \ If the value is completely 0 I think it means write protect 1 and 0<> ( error? ) write-disable - #writes 1+ to #writes ;
\ Assumes that the range doesn't straddle a page boundary @@ -285,15 +293,54 @@ dma-release ( error? ) ;
-: dma-write-page ( adr page# -- error? ) \ Size is fixed +: start-write-page ( adr page# -- ) \ Size is fixed write-enable ( adr page# ) 0 set-page ( adr ) h# 800 h# 80e false dma-setup ( ) write-cmd h# 4800.0110 cmd wait-cmd ( ) \ Auto-ECC, RS, write cmd +; +: dma-write-page ( adr page# -- error? ) \ Size is fixed + start-write-page wait-write-done ( error? ) \ dma-release ; +: async-write-page ( adr page# -- prev-error? ) + wait-write-done if 2drop true exit then + start-write-page + 0 +;
+: fast-write-pages ( adr page# #pages -- #written ) + write-enable + dup >r + begin dup while ( adr page# #rem r: #pages ) + over 0 set-page ( adr page# #rem ) + 2 pick h# 800 h# 80e false dma-setup ( adr page# #rem ) + write-cmd h# 4800.0110 ( adr page# #rem cmd cmd2 ) + cached-write? if ( adr page# #rem cmd cmd2 ) + 2 pick 1 <> if ( adr page# #rem cmd cmd2 ) + 5 + \ make cmd2 cached write ( adr page# #rem cmd cmd2 ) + then ( adr page# #rem cmd cmd2 ) + then ( adr page# #rem cmd cmd2 ) + cmd wait-cmd ( adr page# #rem ) + \ For normal write, this waits for completion. + \ For cached write, it waits until the cache register is free. + (wait-write-done) dup 3 and if ( adr page# #rem status ) + \ If the 2 bit is set, the error was on the previous page + \ during the program operation. Otherwise the error was + \ on the current page during the download. + 2 and if 1+ then ( adr page# #rem ) + \ Calculate #written + nip nip r> swap - exit + else ( adr page# #rem status ) + drop ( adr page# #rem ) + then ( adr page# #rem ) + rot h# 800 + rot 1+ rot 1- ( adr' page#' #rem' ) + repeat ( adr page# #rem r: #pages ) + 3drop r> + write-disable +; + : write-page ( adr page# -- error? ) dma-write-page ; : write-bytes ( adr len page# offset -- error? ) pio-write-raw ;
Modified: dev/olpc/cafenand/configure.fth =================================================================== --- dev/olpc/cafenand/configure.fth 2008-12-04 09:17:39 UTC (rev 1012) +++ dev/olpc/cafenand/configure.fth 2008-12-04 09:17:43 UTC (rev 1013) @@ -51,7 +51,15 @@ to pages/chip ;
+: configure-capabilities ( adr -- adr ) + dup 2 + c@ ( adr id3 ) + dup h# 80 and 0<> to cached-write? + dup h# 40 and 0<> to interleave? + 4 rshift 3 and 1 swap lshift to #simultaneous-writes +; + : configure-auto ( adr -- adr ) + configure-capabilities pages-auto configure-size ;
Modified: dev/olpc/cafenand/lbanand.fth =================================================================== --- dev/olpc/cafenand/lbanand.fth 2008-12-04 09:17:39 UTC (rev 1012) +++ dev/olpc/cafenand/lbanand.fth 2008-12-04 09:17:43 UTC (rev 1013) @@ -18,7 +18,7 @@ tuck set-page ( adr #sectors ) sectors>bytes ( adr #bytes ) dup false dma-setup ( ) - h# e220.0080 h# 0000.0110 cmd wait-cmd ( ) \ No ECC, write cmd + h# e220.0080 h# 0000.0110 cmd ( ) \ No ECC, write cmd wait-write-done ( error? ) \ dma-release ;
