Author: wmb Date: Mon Jan 16 22:05:06 2012 New Revision: 2825 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2825
Log: decomp.fth - minor tweaks.
Modified: forth/lib/decomp.fth
Modified: forth/lib/decomp.fth ============================================================================== --- forth/lib/decomp.fth Mon Jan 16 22:05:01 2012 (r2824) +++ forth/lib/decomp.fth Mon Jan 16 22:05:06 2012 (r2825) @@ -17,8 +17,6 @@ \ own special compiling words, it will be easy to change the \ decompiler to include them. This code is implementation \ dependant, and will not necessarily work on other Forth system. -\ However, most of the machine dependencies have been isolated into a -\ separate file "decompiler.m.f". \ To invoke the decompiler, use the word SEE <name> where <name> is the \ name of a Forth word. Alternatively, (SEE) will decompile the word \ whose acf is on the stack. @@ -111,7 +109,8 @@ \ what kind of branch target it is (either a begin, for backward branches, \ a then, for forward branches, or an exit.
-40 /n* buffer: breaks +80 /n* constant /breaks +/breaks buffer: breaks variable end-breaks
variable break-type variable break-addr variable where-break @@ -185,7 +184,7 @@ : .$endcase ( ip -- ip' ) indent .." $endcase" indent ta1+ ;
: add-break ( break-address break-type -- ) - end-breaks @ breaks 40 /n* + >= ( adr,type full? ) + end-breaks @ breaks /breaks + >= ( adr,type full? ) abort" Decompiler internal table overlow" ( adr,type ) end-breaks @ breaks > if ( adr,type ) over end-breaks @ /n 2* - >r r@ 2@ ( adr,type adr prev-adr,type ) @@ -242,7 +241,7 @@ : scan-;code ( ip -- ip' | 0 ) does-ip? 0= if drop 0 then ; : .;code (s ip -- ip' ) does-ip? if - .." does> " + cr lmargin @ spaces ." does> " else 0 lmargin ! indent .." ;code " cr disassemble 0 then @@ -358,7 +357,7 @@ #decomp-classes 1+ case: .execution-class ( ip index -- ip' ) ( 0 ) .inline ( 1 ) .?branch ( 2 ) .branch ( 3 ) .loop - ( 4 ) .+loop ( 6 ) .do + ( 4 ) .+loop ( 5 ) .do ( 6 ) .compile ( 7 ) .string ( 8 ) .string ( 9 ) .;code ( 10 ) .unnest ( 11 ) .string
