Author: wmb Date: Wed Mar 21 23:14:01 2012 New Revision: 2909 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2909
Log: Decompiler - fixed the indentation logic (it sometimes messed up on repeated conditionals or loops) and added h#/d# number prefixes.
Modified: forth/lib/decomp.fth
Modified: forth/lib/decomp.fth ============================================================================== --- forth/lib/decomp.fth Wed Mar 21 06:42:47 2012 (r2908) +++ forth/lib/decomp.fth Wed Mar 21 23:14:01 2012 (r2909) @@ -54,7 +54,7 @@ defer (see)
hidden definitions -d# 200 2* /n* constant /positions +d# 300 2* /n* constant /positions /positions buffer: positions 0 value end-positions \ 0 value line-after-; @@ -70,14 +70,14 @@ 2 /n* +loop ( ip ) drop true ( true ) ; -0 value the-ip +0 value decompiler-ip : add-position ( ip -- ) - the-ip find-position if ( ) + decompiler-ip find-position if ( ) end-positions positions /positions + >= ( flag ) abort" Decompiler position table overflow" ( ) end-positions dup 2 na+ is end-positions ( adr ) then ( adr ) - #out @ #line @ wljoin the-ip rot 2! ( ) + #out @ #line @ wljoin decompiler-ip rot 2! ( ) ; : ip>position ( ip -- true | #out #line false ) find-position if ( ) @@ -91,10 +91,20 @@ ip>position 0= if at-xy then ;
+headers +defer indent +: (indent) ( -- ) lmargin @ #out @ - 0 max spaces ; +' (indent) is indent +headerless + +: +indent ( -- ) 3 lmargin +! cr ; +: -indent ( -- ) ??cr -3 lmargin +! ; +\ : <indent ( -- ) ??cr -3 lmargin +! indent 3 lmargin +! ; + headerless \ Like ." but goes to a new line if needed. : cr". ( adr len -- ) - dup ?line ( adr len ) + dup ?line indent ( adr len ) add-position ( adr len ) magenta-letters type cancel ( ) ; @@ -198,21 +208,9 @@ then
; -headers -defer indent -: (indent) ( -- ) - #out @ lmargin @ > if cr then - lmargin @ #out @ - spaces -; -' (indent) is indent -headerless - -: +indent ( -- ) 3 lmargin +! indent ; -: -indent ( -- ) -3 lmargin +! indent ; -: <indent ( -- ) -3 lmargin +! indent 3 lmargin +! ;
: .begin ( -- ) .." begin " +indent ; -: .then ( -- ) -indent .." then " ; +: .then ( -- ) -indent .." then" cr ;
\ Extent holds the largest known extent of the current word, as determined \ by branch targets seen so far. This is used to decide if an exit should @@ -220,10 +218,10 @@ variable extent extent off : +extent ( possible-new-extent -- ) extent @ umax extent ! ; : +branch ( ip-of-branch -- next-ip ) ta1+ /branch + ; -: .endof ( ip -- ip' ) .." endof" indent +branch ; -: .endcase ( ip -- ip' ) indent .." endcase" indent ta1+ ; -: .$endof ( ip -- ip' ) .." $endof" indent +branch ; -: .$endcase ( ip -- ip' ) indent .." $endcase" indent ta1+ ; +: .endof ( ip -- ip' ) .." endof" cr +branch ; +: .endcase ( ip -- ip' ) .." endcase" cr ta1+ ; +: .$endof ( ip -- ip' ) .." $endof" cr +branch ; +: .$endcase ( ip -- ip' ) .." $endcase" cr ta1+ ;
: add-break ( break-address break-type -- ) end-breaks @ breaks /breaks + >= ( adr,type full? ) @@ -283,36 +281,36 @@ : scan-;code ( ip -- ip' | 0 ) does-ip? 0= if drop 0 then ; : .;code (s ip -- ip' ) does-ip? if - cr lmargin @ spaces ." does> " + ??cr .." does> " else - 0 lmargin ! indent .." ;code " cr disassemble 0 + ??cr 0 lmargin ! .." ;code " cr disassemble 0 then ; : .branch ( ip -- ip' ) dup forward-branch? if - <indent .." else" indent + -indent .." else" +indent else - -indent .." repeat " + -indent .." repeat" cr then +branch ; : .?branch ( ip -- ip' ) dup forward-branch? if dup while? if - <indent .." while" indent + -indent .." while" +indent else - .." if " +indent + .." if" +indent then else - -indent .." until " + -indent .." until " cr then +branch ;
: .do ( ip -- ip' ) .." do " +indent +branch ; : .?do ( ip -- ip' ) .." ?do " +indent +branch ; -: .loop ( ip -- ip' ) -indent .." loop " +branch ; -: .+loop ( ip -- ip' ) -indent .." +loop " +branch ; +: .loop ( ip -- ip' ) .." loop " cr +branch ; +: .+loop ( ip -- ip' ) -indent .." +loop " cr +branch ; : .of ( ip -- ip' ) .." of " +branch ; : .$of ( ip -- ip' ) .." $of " +branch ;
@@ -343,8 +341,15 @@
: pretty-. ( n -- ) base @ d# 10 = if (.) else (u.) then ( adr len ) - dup ?line add-position - green-letters type cancel space + dup 3 + ?line indent add-position + green-letters + base @ case + d# 10 of ." d# " endof + d# 16 of ." h# " endof + d# 8 of ." o# " endof + d# 2 of ." b# " endof + endcase + type cancel space ;
: .compiled ( ip -- ip' ) @@ -354,6 +359,7 @@ ta1+ ( ip' ) ; : .word ( ip -- ip' ) + indent dup token@ check-[compile] ( ip xt ) >name name>string ( ip adr len ) dup ?line add-position ( ip adr len ) @@ -378,7 +384,7 @@ headers : skip-(') ( ip -- ip' ) ta1+ ta1+ ; headerless -: .is ( ip -- ip' ) .." to " ta1+ dup token@ .name ta1+ ; +: .is ( ip -- ip' ) .." to " ta1+ dup token@ .name ta1+ ; : .string ( ip -- ip' ) cword-name .string-tail +str ; : .nstring ( ip -- ip' ) ta1+ dup ncount " n""" .string-tail +nstr ;
@@ -387,7 +393,7 @@
: .unnest ( ip -- ip' ) dup extent @ u>= if - 0 lmargin ! indent .." ; " drop 0 + ??cr 0 lmargin ! .." ;" drop 0 else .." exit " ta1+ then @@ -498,8 +504,9 @@ init-positions ( apf ) dup scan-pf next-break 3 lmargin ! indent ( apf ) begin ( adr ) - dup is the-ip ( adr ) - ?cr break-addr @ over = if ( adr ) + dup is decompiler-ip ( adr ) + ?cr ( adr ) + break-addr @ over = if ( adr ) begin ( adr ) break-type @ execute ( adr ) next-break break-addr @ over <> ( adr done? ) @@ -525,7 +532,7 @@ pop-base ; \ Display category of word -: .: ( acf definer -- ) .definer space space >body .pf ; +: .: ( acf definer -- ) .definer cr ( space space ) >body .pf ; : debug-see ( apf -- ) page-mode? >r no-page find-cfa ['] : .:
