Author: wmb Date: 2009-10-03 00:03:37 +0200 (Sat, 03 Oct 2009) New Revision: 1388
Modified: cpu/x86/pc/olpc/via/addrs.fth cpu/x86/pc/olpc/via/demodram.fth cpu/x86/pc/olpc/via/dramtiming.fth cpu/x86/pc/olpc/via/probemem.fth cpu/x86/pc/olpc/via/romreset.bth cpu/x86/pc/olpc/via/startgfxinit.fth cpu/x86/pc/olpc/via/starthostctl.fth Log: Via - support 32-bit memory width controlled by memory ID1 jumper.
Modified: cpu/x86/pc/olpc/via/addrs.fth =================================================================== --- cpu/x86/pc/olpc/via/addrs.fth 2009-10-02 22:00:49 UTC (rev 1387) +++ cpu/x86/pc/olpc/via/addrs.fth 2009-10-02 22:03:37 UTC (rev 1388) @@ -19,7 +19,8 @@
dropin-base h# 20 + constant ResetBase \ Location of "reset" dropin in ROM
-h# 3b00.0000 value fw-pa \ Changed in probemem.fth +0 value fw-pa \ Set in probemem.fth +\ h# 3b00.0000 value fw-pa \ Changed in probemem.fth \ h# 3bc0.0000 value fw-pa \ Changed in probemem.fth \ h# 1bc0.0000 value fw-pa \ Changed in probemem.fth \ h# bc0.0000 value fw-pa \ Changed in probemem.fth @@ -38,7 +39,8 @@
h# 40.0000 constant /dma-extra \ In case the firmware region isn't enough /fw-ram /dma-extra + constant dma-size \ We let the DMA area overlap the FW area -fw-pa /dma-extra - constant dma-base +\ fw-pa /dma-extra - constant dma-base +0 value dma-base \ Set in probemem.fth
h# f.0000 constant suspend-base \ In the DOS hole h# f.0008 constant resume-entry
Modified: cpu/x86/pc/olpc/via/demodram.fth =================================================================== --- cpu/x86/pc/olpc/via/demodram.fth 2009-10-02 22:00:49 UTC (rev 1387) +++ cpu/x86/pc/olpc/via/demodram.fth 2009-10-02 22:03:37 UTC (rev 1388) @@ -375,7 +375,9 @@
56 ff 00 mreg \ Rank map B ? 57 ff 00 mreg \ Rank map B ? + end-table
+ 0 3 devfunc 40 ff rank-top0 mreg \ Rank top 0 (register value in units of 64MB) 41 ff rank-top1 mreg \ Rank top 1 42 ff rank-top2 mreg \ Rank top 2 @@ -387,17 +389,20 @@ 4b ff rank-base3 mreg \ Rank base 3 end-table
- h# 15 port80 + acpi-io-base 48 + port-rl h# 1000.0000 # ax and 0<> if \ Memory ID1 bit + 0 3 devfunc + 6c 20 20 mreg \ Enable 32-bit memory width mode - channel A + d4 30 10 mreg \ ODT off for low 32 bits + end-table
- total-size 8f60 config-wb \ DRAM Bank 7 ending address - controls DMA upstream - 0388 config-rb ax bx mov 0385 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to reg 85 - 0388 config-rb ax bx mov 8fe5 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to SB Low Top e5 + 0388 config-rb ax bx mov 1 # bx shr 0385 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to reg 85 + else + 0388 config-rb ax bx mov 0385 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to reg 85 + then
-\ d# 17 7 devfunc -\ e6 ff 07 mreg \ Enable Top, High, and Compatible SMM -\ end-table + h# 15 port80
-1 [if] \ Very simple memtest +0 [if] \ Very simple memtest long-offsets on ax ax xor h# 12345678 # bx mov \ Data value to write to address 0 @@ -464,7 +469,7 @@
h# 17 port80
-1 [if] +0 [if] ax ax xor h# 12345678 # bx mov bx 0 [ax] mov
Modified: cpu/x86/pc/olpc/via/dramtiming.fth =================================================================== --- cpu/x86/pc/olpc/via/dramtiming.fth 2009-10-02 22:00:49 UTC (rev 1387) +++ cpu/x86/pc/olpc/via/dramtiming.fth 2009-10-02 22:03:37 UTC (rev 1388) @@ -85,3 +85,12 @@
rank-size #ranks * constant total-size [then] + +h# 400.0000 constant /fbmem +: >fbmem-base ( size/64M -- low high ) + d# 26 lshift ( memsize-in-bytes ) + /fbmem - ( memsize-less-framebuf-size ) + d# 21 rshift wbsplit ( low high ) +; + +: dblfudge32 2/ ;
Modified: cpu/x86/pc/olpc/via/probemem.fth =================================================================== --- cpu/x86/pc/olpc/via/probemem.fth 2009-10-02 22:00:49 UTC (rev 1387) +++ cpu/x86/pc/olpc/via/probemem.fth 2009-10-02 22:03:37 UTC (rev 1388) @@ -5,30 +5,13 @@ 0 value total-ram-cached : total-ram ( -- ramsize ) total-ram-cached ?dup if exit then - \ Search for the last "top of rank" value - h# 340 h# 343 do - i config-b@ ?dup if ( chunks ) \ Each chunk is 64 MiB - d# 26 lshift ( bytes ) - dup to total-ram-cached - unloop exit - then - -1 +loop - ." Can't get total RAM size!" cr - h# 1000.0000 + h# 385 config-b@ d# 24 lshift dup to total-ram-cached ;
-\ Offset of frame buffer/display memory within the memory array -: fb-offset ( -- offset ) mem-info-pa 4 + l@ ; +\ Excludes RAM assigned to the frame buffer and used by OFW page tables +: system-ram ( -- offset ) mem-info-pa 4 + l@ ;
-\ Excludes RAM assigned to the frame buffer -: system-ram ( -- extant avail ) - fb-offset -; - -\ This may require adjustment if we steal additional SMI memory -: fbsize ( -- ) total-ram fb-offset - ; - dev /memory
\ Excludes RAM already used for page tables
Modified: cpu/x86/pc/olpc/via/romreset.bth =================================================================== --- cpu/x86/pc/olpc/via/romreset.bth 2009-10-02 22:00:49 UTC (rev 1387) +++ cpu/x86/pc/olpc/via/romreset.bth 2009-10-02 22:03:37 UTC (rev 1388) @@ -60,8 +60,10 @@ fload ${BP}/cpu/x86/pc/olpc/via/startmacros.fth \ Via-oriented startup macros
fload ${BP}/cpu/x86/pc/olpc/via/dramtiming.fth +fload ${BP}/cpu/x86/pc/mmxdot.fth
start-assembling +ResetBase to asm-origin \ Necessary for mmxdot
hex
@@ -72,6 +74,7 @@ fload ${BP}/cpu/x86/pc/romfind.fth \ find-dropin subroutine
[ifdef] debug-startup +fload ${BP}/cpu/x86/pc/mmxdotcode.fth \ Memoryless numeric output fload ${BP}/cpu/x86/pc/dot.fth \ Numeric output subroutine \ fload ${BP}/cpu/x86/pc/olpc/via/startinteract.fth \ emitpause subroutine [then] @@ -90,6 +93,10 @@ 2 92 port-wb \ Enable A20 \ External A20GATE is disabled automatically because the internal KBC is on by default (cfg reg 8851 bit 0)
+ acpi-io-base 1 + 8888 config-ww \ Set ACPI base address +\ 88 8881 config-wb \ Enable ACPI regs, 32-bit PM timer, guard RTC against power glitches + 8c 8881 config-wb \ Enable ACPI regs, 32-bit PM timer, guard RTC against power glitches + fload ${BP}/cpu/x86/pc/olpc/via/startcacheasram.fth
\ cache_as_ram_auto.c: amd64_main() @@ -105,14 +112,9 @@ \ This needs to be done early so we can test various GPIO bits, \ including SERIAL_EN
- acpi-io-base 1 + 8888 config-ww \ Set ACPI base address - 8c 8881 config-wb \ Enable ACPI regs, 32-bit PM timer, guard RTC against power glitches +\ acpi-io-base 1 + 8888 config-ww \ Set ACPI base address +\ 8c 8881 config-wb \ Enable ACPI regs, 32-bit PM timer, guard RTC against power glitches
-[ifdef] debug-startup - cominit #) call -[then] - - char + report h# 1d port80
\ This is a device ID backdoor to fake out the ID so Ubuntu will install @@ -120,6 +122,11 @@
fload ${BP}/cpu/x86/pc/olpc/via/starthostctl.fth
+[ifdef] debug-startup + cominit #) call +[then] + + char + report long-offsets on
acpi-io-base 4 + port-rw \ Get APCI Status register @@ -138,9 +145,15 @@
\ This must be done in both the power-up and resume-from-S3 cases, \ since the registers in D17F7 lose state during S3. - total-size 8f60 config-wb \ DRAM Bank 7 ending address - controls DMA upstream - 0388 config-rb ax bx mov 8fe5 config-setup bx ax mov al dx out \ Copy Low Top from RO reg 88 to SB Low Top e5
+ 0385 config-rb ax bx mov 8fe5 config-setup bx ax mov al dx out \ Copy Low Top from reg 85 to SB Low Top e5 + 0385 config-rb ax bx mov 8f60 config-setup bx ax mov al dx out \ Copy Low Top from reg 85 to SB Bank 7 end 60 + +\ d# 17 7 devfunc +\ e6 ff 07 mreg \ Enable Top, High, and Compatible SMM +\ end-table + + fload ${BP}/cpu/x86/pc/olpc/via/startgfxinit.fth
0 [if] \ Fire up C Forth @@ -167,8 +180,34 @@ h# ffff.0000 # ax mov ax jmp [then]
-\ fload ${BP}/cpu/x86/pc/ramtest.fth +0 [if] +long-offsets on +acpi-io-base 48 + port-rl h# 1000.0000 # ax and 0<> if \ Memory ID1 bit
+ mmxcr + 39 3c4 port-wb ax ax xor 3c5 port-rb ax mmxdot + 68 3c4 port-wb ax ax xor 3c5 port-rb ax mmxdot + 6d 3c4 port-wb ax ax xor 3c5 port-rb ax mmxdot + 6e 3c4 port-wb ax ax xor 3c5 port-rb ax mmxdot + 6f 3c4 port-wb ax ax xor 3c5 port-rb ax mmxdot mmxcr + + h# 08b0 # ax mov ax mmxdot mmxcr + h# 08b0 h# 10 mmxcfg-dump + + h# 0200 # ax mov ax mmxdot mmxcr + h# 0200 h# 100 mmxcfg-dump + + h# 0300 # ax mov ax mmxdot mmxcr + h# 0300 h# 100 mmxcfg-dump + + h# 00100000 # ax mov ax mmxdot mmxcr + h# 00100000 to ramtest-start + ramtest-start h# 1a00.0000 + to ramtest-end + fload ${BP}/cpu/x86/pc/ramtest.fth +then +long-offsets off +[then] + fload ${BP}/cpu/x86/pc/olpc/via/startmtrrinit.fth
fload ${BP}/cpu/x86/pc/olpc/via/ioinit.fth
Modified: cpu/x86/pc/olpc/via/startgfxinit.fth =================================================================== --- cpu/x86/pc/olpc/via/startgfxinit.fth 2009-10-02 22:00:49 UTC (rev 1387) +++ cpu/x86/pc/olpc/via/startgfxinit.fth 2009-10-02 22:03:37 UTC (rev 1388) @@ -11,20 +11,21 @@ \ de ff 06 mreg \ Enable CHA and CHB merge mode (but description says this value disable merging!) 00 for compatibility end-table
-\ 0 3 devfunc -\ a1 70 40 mreg \ Set frame buffer size to 64M (8M:10, 16M:20, 32M:30, etc) - fbsize -\ end-table - 1 0 devfunc - \ Reg 1b2 controls the number of writable bits in the BAR at 810 - b2 ff 70 mreg \ Offset of frame buffer, depends on size - fbsize - 04 ff 07 mreg \ Enable IO and memory access to display + \ Reg 1b2 is a mask of the number of writable bits in the BAR at 810 + \ It depends on the size that is chosen for the frame buffer memory + /fbmem 1- invert d# 22 rshift h# 7f also forth and previous + b2 ff rot mreg \ Offset of frame buffer, depends on size + 04 ff 07 mreg \ Enable IO and memory access to display end-table
- d000.0000 810 config-wl \ S.L. Base address - f000.0000 814 config-wl \ MMIO Base address - cd01 3a0 config-ww \ Set frame buffer size and CPU-relative address and enable + fb-pci-base 810 config-wl \ S.L. Base address + gfx-pci-base 814 config-wl \ MMIO Base address
+ /fbmem log2 d# 22 - d# 12 lshift + fb-pci-base d# 21 rshift 1 lshift + + h# 8001 + 3a0 config-ww \ Set frame buffer size and CPU-relative address and enable + 0 0 devfunc c6 02 02 mreg \ Enable MDA forwarding (not in coreboot) d4 00 03 mreg \ Enable MMIO and S.L. access in Host Control device @@ -39,25 +40,35 @@ 10 3c4 port-wb 01 3c5 port-wb \ Turn off register protection 67 3c2 port-wb \ Enable CPU Display Memory access (2), use color not mono port (1)
- 68 3c4 port-wb e0 3c5 port-wb \ Size of System Local Frame Buffer - Value depends on frame buffer size - fbsize + /fbmem 1- invert d# 21 rshift ( size-code ) + 68 3c4 port-wb ( size ) 3c5 port-wb \ Size of System Local Frame Buffer - Value depends on frame buffer size \ 00:512MB 80:256MB c0:128MB e0:64MB f0:32MB f8:16MB fc:8MB fe:4MB ff:2MB
\ These 2 are scratch registers that communicate with the VGA BIOS 3d 3d4 port-wb 74 3d5 port-wb \ Value depends on DIMM frequency - used by VGA BIOS - 39 3c4 port-wb 10 3c5 port-wb \ BIOS Reserved Register 0 - FBsize_MiB/4 - fbsize - VGA BIOS + 39 3c4 port-wb /fbmem d# 22 rshift 3c5 port-wb \ BIOS Reserved Register 0 - FBsize_MiB/4 - VGA BIOS
5a 3c4 port-wb 01 3c5 port-wb \ Point to secondary registers 4c 3c4 port-wb 83 3c5 port-wb \ LCDCK Clock Synthesizer Value 2 5a 3c4 port-wb 00 3c5 port-wb \ Point back to primary registers
- 6d 3c4 port-wb e0 3c5 port-wb \ Base address [28:21] of SL in System Memory - base is 1c00.0000 - fbsize, memsize + [ifdef] demo-board - 6e 3c4 port-wb 00 3c5 port-wb \ Base address [36:29] of SL in System Memory + 6d 3c4 port-wb total-size >fbmem-base drop 3c5 port-wb \ Base address [28:21] of SL in System Memory + 6e 3c4 port-wb total-size >fbmem-base nip 3c5 port-wb \ Base address [36:29] of SL in System Memory + 6f 3c4 port-wb 00 3c5 port-wb \ Base address [47:37] of SL in System Memory [then] [ifdef] xo-board - 6e 3c4 port-wb 01 3c5 port-wb \ Base address [36:29] of SL in System Memory + 385 config-rb \ AX: totalsize/16M + d# 24 # ax shl \ AX: totalsize + /fbmem # ax sub \ AX: totalsize-fbmemsize = fbbase + d# 21 # ax shr \ AX: fbbase/2M + ax bx mov \ BX: fbbase/2M + + 6d 3c4 port-wb bl al mov 3c5 # dx mov al dx out \ Base address [28:21] of SL in System Memory + 6e 3c4 port-wb bh al mov 3c5 # dx mov al dx out \ Base address [36:29] of SL in System Memory + 6f 3c4 port-wb d# 16 # bx shr bl al mov 3c5 # dx mov al dx out \ Base address [47:37] of SL in System Memory [then] - 6f 3c4 port-wb 00 3c5 port-wb \ Base address [47:37] of SL in System Memory
36 3c4 port-wb 11 3c5 port-wb \ Subsystem Vendor ID 1 35 3c4 port-wb 06 3c5 port-wb \ Subsystem Vendor ID 0
Modified: cpu/x86/pc/olpc/via/starthostctl.fth =================================================================== --- cpu/x86/pc/olpc/via/starthostctl.fth 2009-10-02 22:00:49 UTC (rev 1387) +++ cpu/x86/pc/olpc/via/starthostctl.fth 2009-10-02 22:03:37 UTC (rev 1388) @@ -66,3 +66,17 @@ 51 ff f8 mreg \ Last step - enable DRDY timing [then] end-table + + acpi-io-base 48 + port-rl h# 1000.0000 # ax and 0<> if \ Memory ID1 bit + 0 2 devfunc + 55 02 02 mreg \ Host controller to DRAM read cycle control II - 1 means 2T slower + + 60 ff ff mreg \ DRDY Timing Control 1 for Read Line + 61 ff ff mreg \ DRDY Timing Control 2 for Read Line + 63 ff ff mreg \ DRDY Timing Control 1 for Read QW + 64 ff ff mreg \ DRDY Timing Control 2 for Read QW + 66 ff ff mreg \ Burst DRDR Timing Control for Second cycle in burst + + 90 03 00 mreg \ Host controller to DRAM read cycle control III - 00 means 2T faster + end-table + then
