Author: wmb Date: 2009-11-26 01:31:26 +0100 (Thu, 26 Nov 2009) New Revision: 1517
Added: dev/nullscreen.fth dev/ramdisk.fth Log: Checked in ramdisk driver and null screen driver.
Added: dev/nullscreen.fth =================================================================== --- dev/nullscreen.fth (rev 0) +++ dev/nullscreen.fth 2009-11-26 00:31:26 UTC (rev 1517) @@ -0,0 +1,37 @@ +\ See license at end of file +purpose: Null driver that no-ops some screen primitives, for testing + +dev /null +: graphmem load-base ; +: erase-screen ; +: fill-rectangle 4drop drop ; +: draw-rectangle 4drop drop ; +: draw-transparent-rectangle 4drop drop ; +true value vga? +: set-source to vga? ; +dend +devalias screen //null + +\ LICENSE_BEGIN +\ Copyright (c) 2009 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Added: dev/ramdisk.fth =================================================================== --- dev/ramdisk.fth (rev 0) +++ dev/ramdisk.fth 2009-11-26 00:31:26 UTC (rev 1517) @@ -0,0 +1,77 @@ +\ See license at end of file +purpose: Block-method additions to subrange.fth device to make a RAMdisk device + +0 0 " b000000" " /" begin-package + " ramdisk" device-name + h# 3800000 constant /device + +external +\ /device must be defined externally as the length of the subrange +\ my-space is the base of the subrange +my-address my-space /device reg + +0 value offset \ seek pointer + +: clip-size ( adr len -- adr actual ) + offset + /device min offset - ( adr actual ) +; +: update-ptr ( actual -- actual ) dup offset + to offset ; + +external +: open ( -- flag ) 0 to offset true ; +: close ( -- ) ; + +: seek ( d.offset -- status ) + 0<> over /device u> or if drop true exit then \ Seek offset too large + to offset + false +; +: read ( adr len -- actual ) + clip-size ( adr actual ) + tuck offset my-space + -rot move ( actual ) + update-ptr +; +: write ( adr len -- actual ) + clip-size ( adr actual ) + tuck offset my-space + swap move ( actual ) + update-ptr +; +: size ( -- d ) /device 0 ; + + +h# 200 value block-size +: #blocks ( -- n ) /device block-size / ; +: read-blocks ( adr block# #blocks -- actual-#blocks ) + swap block-size um* seek if 2drop 0 exit then ( adr #blocks ) + block-size * read block-size * +; +: write-blocks ( adr block# #blocks -- actual-#blocks ) + swap block-size um* seek if 2drop 0 exit then ( adr #blocks ) + block-size * write block-size * +; + +end-package + +\ LICENSE_BEGIN +\ Copyright (c) 2009 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
