Author: wmb Date: 2009-10-30 08:52:42 +0100 (Fri, 30 Oct 2009) New Revision: 1449
Modified: dev/usb2/device/storage/scsi.fth dev/usb2/device/storage/scsidisk.fth Log: OLPC trac 9423 - USB mass storage driver - Made csw timeouts retryable to work around a problem with a Kingston USB key. The problem could be in the hardware but I was unable to solve it and the retry seems to make the system work stably.
Modified: dev/usb2/device/storage/scsi.fth =================================================================== --- dev/usb2/device/storage/scsi.fth 2009-10-30 07:46:16 UTC (rev 1448) +++ dev/usb2/device/storage/scsi.fth 2009-10-30 07:52:42 UTC (rev 1449) @@ -104,12 +104,14 @@ r> /cbw ( cbw-adr,len ) ;
-: (get-csw) ( -- len usberr ) csw /csw bulk-in-pipe bulk-in ; +: (get-csw) ( -- len usberr ) csw /csw erase csw /csw bulk-in-pipe bulk-in ; : get-csw ( -- len usberr ) (get-csw) dup if 2drop (get-csw) then ;
-d# 15,000 constant bulk-timeout +\ This used to be 15 seconds but I shortened it so timeouts can be +\ retried without having to wait too long. +d# 2,000 constant bulk-timeout
: (execute-command) ( data-adr,len dir cbw-adr,len -- actual-len cswStatus ) debug? if @@ -136,7 +138,13 @@
rot drop ( actual csw-len csw-usberror )
- ?dup if nip exit then ( actual csw-len csw-usberror ) + ?dup if ( actual csw-len csw-usberror ) + nip ( actual csw-usberror ) + dup h# 10000000 = if ( actual csw-usberror ) + 2drop 0 2 ( 0 2 ) \ Convert timeout error to a retry + then ( actual usberror ) + exit + then ( actual csw-len csw-usberror ) drop ( actual )
debug? if
Modified: dev/usb2/device/storage/scsidisk.fth =================================================================== --- dev/usb2/device/storage/scsidisk.fth 2009-10-30 07:46:16 UTC (rev 1448) +++ dev/usb2/device/storage/scsidisk.fth 2009-10-30 07:52:42 UTC (rev 1449) @@ -213,6 +213,8 @@ read-block-extent if false exit then ( block-size #blocks ) to #blocks to block-size
+ d# 2000 set-timeout + init-deblocker 0= if false exit then
init-label-package 0= if
